07-24-2007, 10:47 PM | #1 |
Rock Stacker Join Date: Nov 2006 Location: Vancouver
| My 1st Custom 1.9 Scale Build
this is my first try in building a scale rig. it is not finished yet, have to make some mounting for the electronics and battery. at least, it is a roller now . thanks for looking... feel free to post any comments/suggestions... |
07-24-2007, 11:14 PM | #2 |
Pebble Pounder Join Date: Apr 2007 Location: Anchorage
Where did you find the stickers for the lights?
07-24-2007, 11:23 PM | #3 |
07-24-2007, 11:41 PM | #4 |
anyone of you guys tell me how could i fill/get rid of those hollow part in the hood? i know most of you use a styrene stuff but i dont have a source for that here in vancouver so anyone could suggest any alternative material i could use to fill it?
07-25-2007, 12:24 AM | #5 |
Hmmm. Absolutally no styrene at all? do you have a hobbyshop? They should have it.. it's very common... I'm not sure what else. Maybe a polyester glaze puddy? The stuff fo very fine body fillar on cars... Not sure though. The build looks great though. |
07-25-2007, 06:17 AM | #6 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
find some junk plastic cases or something, make sure its kinda flexible.
07-25-2007, 07:32 AM | #7 |
RCC Addict Join Date: Jul 2006 Location: Pasadena
holy driveline angle, batman! looks like a good start!
07-25-2007, 08:15 AM | #8 |
Rock Stacker Join Date: Feb 2005 Location: Orlando, FL
Are those Hummer tires on it? If they are could you get a measurement of how tall they are? The truck looks great. |
07-25-2007, 08:22 AM | #9 |
Rock Stacker Join Date: Feb 2007 Location: Cincinnati
I agree it's a good looking truck. I do have one concern though, the chassis looks sort of bowed in the second photo. It may be a photographic trick and be fine, but figured i'd mention it anyway, just in case.
07-25-2007, 08:46 AM | #10 |
hummer tires and BRGs are 3.5" tall high lifts and slingers are 3.7" |
08-04-2007, 06:45 PM | #11 |
got some update on the scaler. here's some pics of the chassis with the electronics mounted. next step will be the body work... |
08-04-2007, 06:49 PM | #12 |
Rock Crawler Join Date: Feb 2007 Location: CoMo...Kickin it with Holmes Hobbies
if your looking for styrene get on the towerhobbies.com website...they sell all kinds of sizes and textures....looks good.
08-04-2007, 09:17 PM | #13 |
excellent work there man! you have a very clean build so far, i really like how you have everything. however, i think you should swap your electronice to the back and batt to the front. this way alot of the weight is on the front axle, which helps climbing out alot. also for the styrene, you should check out "evergreen" and plastruct adhesive. i really like that combo. cant wait to see where you take this truck. also you should put a skidplate on the underside so you dont get hungup. Last edited by obijuan; 08-04-2007 at 11:15 PM. |
08-04-2007, 11:11 PM | #14 |
Rock Crawler Join Date: Jul 2007 Location: los angeles
looks sweet! i like the way you got everything organised and clean but you might want to put the batt in the front and cover the electronics so you could water proof them
08-05-2007, 12:37 AM | #15 |
Rock Crawler Join Date: Jan 2006 Location: Dallas
Why not just bondo the the hood? If you sand in smooth with real fine sand paper,prime it and sand again with fine sand paper it should work fine. Its not a hole right just an indent? Any ways the chassis looks great! should look awsome when its all painted. You may have mentioned it but what color are you guna paint it?
08-05-2007, 09:26 AM | #16 |
the bondo shrinks and on this scale its noticeable, also the less bondo the better. fill it with as much plastic as possible then putty over it.
08-05-2007, 12:30 PM | #17 |
can i use the tamiya epoxy putty for it? or the body fillers they use in real cars? btw, what kind of primer paints do you guys use? can i use also the primer paints for real car? dont have any idea on what kind of paint should i use for this kind of plastic. sorry for these noob question... i really dont have any idea on paint jobs and body works. thanks for all the tips. |
08-05-2007, 12:47 PM | #18 |
i guess you could use the epoxy putty, and block sand it smooth? and auto primer is good too.
09-04-2007, 09:34 PM | #19 |
the scaler's first time to hit the rock... 9/3/07 |
09-04-2007, 10:56 PM | #20 |
Quarry Creeper Join Date: Aug 2007 Location: Temple
looks good man, looks really good
