02-13-2008, 08:49 AM | #1 |
Rock Crawler Join Date: Aug 2005 Location: Illinois
| roll bar foam question
Anyone know of anthing that looks good to use as roll bar foam, similar to the stuff used on 1:1's? Thanks |
02-13-2008, 10:24 AM | #2 |
Rock Stacker Join Date: Aug 2006 Location: Drexel Hill
I had old cheapie 8mm plug wires hanging around in my basement. I cut the outside rubber cover off by using a razor blade. That ended up looking good on one of my rigs for rollbar padding. I attached it to the rollbar with the mini zipties. Kevin |
02-13-2008, 03:01 PM | #3 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
Try just using strips of felt. Its cheap, comes in any color, and its easy to find. you can glue it on or use mini zips as stated above....
