07-07-2008, 12:33 AM | #1 |
Pebble Pounder Join Date: Jun 2008 Location: Federal Way, WA
| Frame mounted steering servo?
Hey guys, I have parts on the way to start my 2.2 scaler. Actually its what I consider semi scale. It will have a box frame with bumpers, but it will be fourlink coils with a lexan body so It will crawl pretty good and wont cry when it rolls. So, I have searched this site and have seen a few pix of people with frame mounted steering servos. Do they work ok? Any tips on how to position the servo and linkage to not bind up articulation? Is it worth it on a semi scale model? Thanks for any help / insight / opinions!
07-09-2008, 05:53 PM | #2 |
Rock Crawler Join Date: Jan 2005 Location: The Hills
I'm intrested in doing the same with my build. I'd like it to look like my 1:1 jeep but that big servo on the axle doesn't look scale at all! I'm afraid of a huge amount of bump steer once the suspension starts to move around. The distance from the knuckle end to the chassis changes by about an inch when cycled completely. The only way I could think of to remedy that is to run a parallel four link with an equal length track bar. I know it'd look greeat but I'm not sure how well it would perform in 10th scale. Any luck with yours yet? |
07-09-2008, 06:09 PM | #3 |
This works pretty nicely and doesn't bump steer too terribly. You need the link length to be as long as possible, and as parallel to the axle as possible. |
07-09-2008, 06:36 PM | #4 | |
EP is 100% correct, the key to making it work is to have the link from the servo to the knuckle to be as long as you can make it and to have them parallel. | |
07-09-2008, 07:07 PM | #5 |
Newbie Join Date: Jun 2008 Location: Canada
This is just a mock-up for mine.... it seems to work quite well!! I still need to get proper rod and ends..... Here's a link to a video..... http://ca.youtube.com/watch?v=y-INNlJfSUs Steering is on that side for a reason.... ;) Last edited by BigBubba; 07-09-2008 at 07:13 PM. |
07-09-2008, 11:43 PM | #6 |
| thanks
Thanks for the reply's, I has playing around and figured that long and close to parallel was key, and its great that people who have allready done it have confirmed it. A bunch of parts came today, so I get to go out and start planning my build! yeah for me!:-P Rob |
07-09-2008, 11:52 PM | #7 |
| Its been a long day at work and it took me a minute to figure out what you meant. Then I looked closer at the 1:1 rig....ahhh. by the way, thanks to both of you for the video; especially the "no bump steer" video I am convinced now. Rob |
07-12-2008, 08:36 PM | #8 |
Newbie Join Date: Apr 2007 Location: Georgetown
I was having lots of trouble with this but now i see good work Time to get building |
07-24-2008, 06:30 PM | #9 |
Rock Crawler Join Date: Jul 2005 Location: Central Coast
I can't seem to get this to work. Suspension travel severly effects steering while its cycled. I've been working on this tuber for sometime now. I'm at the point where I need to build some upper shock mounts and a servo mount to start wrapping it up. I've ziptied the draglink to the chassis in the area where the servo will be sitting and have been doing my testing like that. I've got a double triangulation 4 link setup with a dinkylink style axle mount. I've tried changing link mounting positions (inside of mount, out side of mount) on the chassis and axle side, both inner and outer link sets, no notable improvement to steering. Drag link length changed from 3" to 5" (the same length as the tierod now), no notable improvement to steering. Draglink angle is only slightly steeper than the picture EP posted up (hard to tell from the picture to be exact though). Beggining to think switching to a parallel 4 link/ trackbar combo is going to be the only answer. Also wondering how well the suspension is going to cycle with that type of setup.. Any ideas? |
07-24-2008, 09:32 PM | #10 | |
07-24-2008, 10:38 PM | #11 | |
RCC Addict Join Date: Aug 2005 Location: VARCOR
07-25-2008, 09:37 AM | #12 | |
I think I'll try the parallel setup and see how that goes. | |
07-25-2008, 01:05 PM | #13 |
Flat drag links are not quite as critical if you use a panhard bar suspension setup. But, it's always good to try and get the drag link as flat as possible. Frame mounted steering is so much cooler than axle mounted, it's always worth the effort in the end. |
07-25-2008, 05:39 PM | #14 |
Rock Crawler Join Date: Feb 2007 Location: Simi Vly
Outstanding job Grizz. I tried and tried to get my steering to look more scale. Never panned out. I would get steering, but, the panhard bar was limiting my suspension. Seeing all these frame steering setups make me want to try again. Just looks way better.
07-25-2008, 05:52 PM | #15 |
| Thanks man. It takes a bit of work, and I had to make many parts like the drop pitman arm, but eventually you can get it I'm sure. |
07-25-2008, 10:03 PM | #16 |
Yep Yep, Just bought a new TLT axle housing to just put the servo on the top. But, after seeing this thread and seeing that it can be done. IT's ON!!. lol.. Another problem I see with mine is that my rig just sits too high from the chassis to the axle. I am gonna lower it a bit more. Mount the servo on the side, and see what happens. I just gotta make a bracket or something for the servo. I have an old Diaz Designs scale chassis that I am using, Gotta make it work. Pics have been very helpful guys. thanks. |
07-25-2008, 10:20 PM | #17 |
Newbie Join Date: May 2008 Location: modesto
kick ass bronco beautiful work. yes i just did my frame mount servo 2 days ago got more steering than i can use works great, but it is trial by fire
07-25-2008, 10:38 PM | #18 |
07-26-2008, 12:44 AM | #19 |
07-31-2008, 02:55 AM | #20 |
| Yes. After reading all the posts here I decided to stop trying to visualize how it will work and just bolt it up. I fabbed a battery tray out of aluminum and mounted my servo to it right against the inside of the frame rail to get the maximum distance out of the drag link. I couldnt get it too parrallel because I have quite a bit of travel. So I set it up so that it is parrallel ( touching actually ) at full bottom out. Suprisingly, there is hardly any bumpsteer to speak of. Not going to be much of a factor at all. Here is a link to a quick video I took of it to show you. Keep in mind its 1:30 in the morning, so I am somewhat incoherent in the recording. http://s508.photobucket.com/albums/s...t=MVI_0118.flv |
