Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: Look what I just ordered.
Old 10-04-2009, 10:09 PM   #1
Default Look what I just ordered.
I've been playing around with brazing and bending for a while and decided to try and do something with it. Any suggestions. My base is going to be the AX10 drive train, I"m thinking along the lines of a rock racer. I ordered the rod instead of tubing so it can take the abuse my 1 and 4 year old will be dishing out.
2
EachMultipurpose Stainless Steel (Type 304/304L) 3/16" Dia, 6' Length
1
PackMetric 18-8 SS Button Head Socket Cap Screw M3 Size, 25 mm Length, .5 mm Pitch, Packs of 50
1
PackMetric 18-8 SS Button Head Socket Cap Screw M3 Size, 40 mm Length, .5 mm Pitch, Packs of 25
8
EachMetric 18-8 SS Unthreaded Round Spacer 6mm OD, 6mm Length, M3 Screw Size (Same as 92871A612)
1
EachSuper Corrosion Resistant SS (Type 316) #2B Mill Finish, 1/16" Thk, 4" Width X 12" Length
2
PacksMetric Type 316 Stainless Steel Hex Nut M3 Size, .5 mm Pitch, 5.5 mm Width, 2.4 mm Height, Packs of 50
1
EachMetric 18-8 Stainless Steel Threaded Rod M3 Size, 1-Meter Length, 0.50 mm Pitch
rlem00 is offline   Reply With Quote
