05-03-2010, 10:19 AM | #1 |
Quarry Creeper Join Date: Mar 2004 Location: Massachusetts
| TTC Quagmire Chevy
We had our TTC comp this past weekend and i had to build a 2.2 version of Mike Neibuhr's Quagmire Chevy from the 1998 Top Truck Challenge. Specs Proline 80 Chevy longbed 2.2 PL beadlock 2.2 RC4WD Mud Slingers 2.2 Wheely King Mud Thrashers TLT front axle King Hauler rear axle Pede Transmission 70mm rear & 90mm front Yeah Racing shocks Stuffed a four link and shocks inbetween the rear tires. Cut out and bent the frame, rear section is only 1.5" wide. stripped the front ring&pinion but had a blast at TTC Last edited by kona_joe; 05-03-2010 at 12:06 PM. Reason: add pic of the 1:1 |
05-03-2010, 10:40 AM | #2 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
Thankyou for all the work this weekend Joe...it was a farken blast GSRCC Drail
05-03-2010, 10:56 AM | #3 |
RCC Addict Join Date: Jan 2010 Location: Barboursville, WV
05-03-2010, 11:57 AM | #4 |
Pebble Pounder Join Date: Jul 2009 Location: Calgary, Ab
That is pretty frickin' neat looking! I don't imagine you get a lot of flex out of the rear suspension before the tires hit the shocks, do you? |
05-03-2010, 12:10 PM | #5 |
Thanks Daryl i cant wait for the next one. I changed the rear shock/lower link mounts around a bit but there still isnt a lot of rear suspension travel. The truck still needs more work... a winch and some detailing etc. |
05-03-2010, 01:12 PM | #6 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
Very cool! With the difference in the tire dia., you are under driving the front ring and pinion versus the rear.......? So Rear is doing more work, front is being pushed a little to make up the difference? Is that why you think the front diff went or other? |
05-03-2010, 02:40 PM | #7 |
Quarry Creeper Join Date: Dec 2005 Location: So Cal
NICE ! ! , good job on that . Any pics of the comp ?
05-03-2010, 03:07 PM | #8 | |
New England TTC Event | |
05-03-2010, 03:09 PM | #9 |
thats sick! i love it!
05-03-2010, 03:26 PM | #10 |
Quarry Creeper Join Date: Dec 2009 Location: Centertown,TN
truck looks great how did you do at TTC? |
05-04-2010, 11:02 AM | #11 |
Don't suppose you can jam a 1 way front diff in that axle, can you?
05-04-2010, 11:22 AM | #12 |
Rock Crawler Join Date: Apr 2008 Location: Albany
You picked what has to be one of the most bad ass chevy trucks in the fu*kinf world. I had forgotten about it. The is perfect truck for inspiration. Do you have the video of that TTC comp? Thanks again Evan |
05-04-2010, 01:33 PM | #13 | |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
Did some quick checking - 2.2 mudslingers are 4.88" according to rc4wd, 2.2 mashers are 4.9" according to towerhobbies. Maybe switching over to mashers in the rear would be a good option for you. Close to the same size, and a better compound for some added rear traction. Awesome looking rig all the same. | |
05-05-2010, 08:24 AM | #14 |
bluechevytuber, I ended up in last place... didnt get to run the Mini Rubicon or Tank Trap due to the lack of 4wd. SlickRockSpider, I agree... also one of my all time favorite Chevy rigs. Nate08, Mashers are not a bad idea, but i'm kinda partial to the look of the Wheely King tires stuffed under the body. I may have a solution figured out. Swap the rear axle out to a narrowed Axial or WK and run the 36/14 2.57 gears and the stock TLT front axle 2.66 5.4" x 2.57:1 / 4.8" = 2.89:1 so the stock 2.66:1 = 8% overdriven Last edited by kona_joe; 05-05-2010 at 08:51 AM. |
05-05-2010, 10:48 AM | #15 |
Quarry Creeper Join Date: Feb 2010 Location: melbourne
That thing is sweet but it looks more like a sled pull truck than a ttc truck but its way cool none the less and if you just cut the side walls of the mashers they would fit on the wk rim so you have the height of the mashers but the look of them being stuffed under the body...what do you think?
05-05-2010, 12:01 PM | #16 |
Rock Crawler Join Date: Nov 2009 Location: Wasilla Alaska
Man had forgotten about that chevy. Sick Sick build keep us up to date on this truck. OH WE NEED VIDEO |
05-14-2010, 07:34 PM | #17 |
Well i took your advice Nate08 and picked up a pair of PL Mashers today. Closer in height to the RC4WD boggers Still looks pretty good |
05-15-2010, 02:36 AM | #18 |
Rock Crawler Join Date: Jul 2004 Location: Salt Lake
05-16-2010, 09:20 AM | #19 |
Howdid the new setup work at the comp?
05-16-2010, 11:31 AM | #20 |
The truck was a lot better. The PL Mashers are a big improvement over the WK tires especially on the rocks. Gate 5 was a narrow climb with a left hand uphill turn on a wet rock covered with moss. I just need to get used to driving with the XL5 speedo now. |
