05-08-2010, 08:40 AM | #1 |
Quarry Creeper Join Date: Jun 2007 Location: santa rosa
| simple trail honcho
xtrail chassis proline beadlocks flatirons novak 45t axial speed control traxxas water proff servo honcho body winch still in the works but its runnable now took it for a run yesterday then came home and made a few tweaks to it and also made some mud flaps for it. cage and bumper on the way |
05-08-2010, 01:29 PM | #2 |
Rock Crawler Join Date: Nov 2005 Location: Winchester
Looking good. Almost looks like mine when I started building it. First stage 2nd Stage |
05-08-2010, 10:02 PM | #3 |
got some more work done today |
05-09-2010, 01:52 PM | #4 |
got the rock sliders on still dont know if im going to do a full cage or not but im thinking of a tool box behind the cab so i can store tow ropes in it |
05-09-2010, 03:41 PM | #5 |
rearanged the bed tool box, raft and spare. also some room for other accesories |
05-11-2010, 02:45 PM | #6 |
well i brought the front end backs ward a little and also strectched the rear end so now the wb is 12 i also tore it down and welded some spots better and ground other spots then i painted it |
05-11-2010, 03:12 PM | #7 |
Pebble Pounder Join Date: Oct 2009 Location: Burbank CA
So how's the traxxas servo performing for you so far? I've been debating getting one since it's plastic gearing...with the amount of rocks we typically run I'm afraid I'll be replacing those gears more often than a Hitec MG servo.
05-11-2010, 03:26 PM | #8 |
id say if you dont have a problem staying out of the water to stay with hitec. ive always had hitec on my rigs but i do run all traxxas waterproff servos on all three of my rigs and one of them as 2.2 roc lox and is quiet a heavy vehicle i have not had any problems with the gears i would definatly say do not use the servo saver with it my buddy does and it barley steers as long as your sterring axle is positioned right they work great |
05-11-2010, 03:29 PM | #9 | |
05-11-2010, 06:32 PM | #10 |
Rock Crawler Join Date: Aug 2009 Location: milton,wv
looks good so far ,whats up with the coils?running them alone without shocks?or just cant make them out
05-11-2010, 06:35 PM | #11 |
05-11-2010, 06:53 PM | #12 |
just running coils wanted to try something different
05-12-2010, 12:33 PM | #13 |
decided to throw some shocks in the front because after i put the shorter links in the front the axle was to sloppy and the front driveshaft would bind |
05-13-2010, 09:58 AM | #14 |
Rock Stacker Join Date: Apr 2009 Location: sterling
a nice clean build, looks good |
05-13-2010, 11:32 AM | #15 |
thank you im thinking i may put leafs in the rear any thoughts or suggestions on that idea? also i mounted the servo on the chassi this morning |
05-13-2010, 11:44 AM | #16 |
| I think adding leafs to the rear will definitely give it a more scale look. How did you mount the servo on the chassis? Did you use the HB CMS kit?
05-13-2010, 02:39 PM | #17 | |
no i mounted the servo to the back of my front bumper if i would have tryed the kit it would have hit the shock there wasnt muchroom to work with | |
05-17-2010, 12:06 PM | #18 |
got some scale accesories mounted ans also leds shovel and keg pick axe front leds probably cant see because of flash on camera rear leds |
05-17-2010, 02:32 PM | #19 |
Newbie Join Date: Jul 2009 Location: Leesport
The winch line, how durable is it rubbing against the rocks. Just curious. I love the loock you are going for.
05-17-2010, 02:39 PM | #20 |
ive broken two whinch lines not on this truck but on my other rigs they will last for awhile and when they break i replace it with picture frame wire also heres a crappy pic but it shows the leds better and the inner fenders which need paint Last edited by 4x4boy; 05-17-2010 at 02:46 PM. |
