Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: CReating completely custom Scaler
Old 12-28-2010, 05:59 AM   #1
Default CReating completely custom Scaler
I am using Losi Nightcrawler axles (all i have) and was wondering how i should attach leaf springs? Or cheap axles that leaf springs easilly attach to. I would prefer the Losi axles because I am low on cash.
Thnks
Crawlercrazy101 is offline   Reply With Quote
Old 12-28-2010, 08:12 AM   #2
I did a build with a leaf sprung losi axle in the rear. What I did was cut a delrin block to fit in between the shock/link mounts and used a screw to attach it then I drilled a hole in the delrin to attach the leaf spring.
This is the only pic that I could find.
Here's the whole build: StIcK kInG's Losi SCX Yota
Hope that helps
Crawln Coles is offline   Reply With Quote
Old 12-28-2010, 08:27 AM   #3
Sweet build! thanks for the help
Tags
custom, ideas, leaf springs, losi, scaler
