04-21-2006, 04:23 PM | #1 |
Newbie Join Date: Feb 2006 Location: scott co.
| hey all here is my scale rig
hey check out my scale rig thanks that is a new bright body i painted up it has locked tlt axles the chassie is a tlt carbin fiber with costum made alum 1-10 couversion add to it and costum made body mounts it's about 11.5" on the wheel base 4 wheel stear motor is stock but has a 12 tooth pinon. has a water prof esc and 2.2 swamp dawgs it flexes up nice for a scale rig i allso made a set of servo mounts for it so the links would mount to them Last edited by fire627man; 05-01-2006 at 10:03 PM. |
04-21-2006, 04:25 PM | #2 |
Rock Crawler Join Date: Jan 2006 Location: Tennessee
it looks good
04-21-2006, 04:27 PM | #3 |
thanks i have a little spot behind my house we built a corse
04-21-2006, 04:31 PM | #4 |
Rock Crawler Join Date: Jan 2006 Location: Dallas
looks good!
04-21-2006, 04:31 PM | #5 |
looks good, nice find on the jeep body. Post up some specs for everyone to see, like wb, cog, motor, trans, chassis, axles, etc. nice work.
04-21-2006, 04:37 PM | #6 |
thanks that is a new bright body i painted upit has locked tlt axles the chassie is a tlt carbin fiber with costum made alum 1-10 couversion add to it and costum made body mounts it's about 11.5" on the wheel base 4 wheel stear motor is stock but has a 12 tooth pinon. has a water prof esc and 2.2 swamp dawgs it flexes up nice for a scale rig i allso made a set of servo mounts for it so the links would mount to them Last edited by fire627man; 04-21-2006 at 04:47 PM. |
04-21-2006, 04:59 PM | #7 |
Throw in some King black foot half shafts, they will get it a slightly wider stance and they are really cheap from tower. Only other thing I would do is maybe drop the body down a lil bit, then it will look great Mike |
04-21-2006, 05:00 PM | #8 |
how could i make it more scale do you think it is too tall
04-21-2006, 05:02 PM | #9 |
i al so have a set of all T's for it and they rub if the body set any lower in fact they rud a little at full flex now that is why thous tires are on it when i crawl
04-21-2006, 05:08 PM | #10 | |
Mike | |
04-21-2006, 05:11 PM | #11 |
it not to bad on the top heavy crawling but a little at top speed with the four wheel stear it will turn on a dime cut all the way it will turn in 3.5' O but i know what you are saying
