03-12-2011, 06:57 PM | #1 |
Quarry Creeper Join Date: Aug 2008 Location: Warwick
| Boyer Poison Spyder
I just got this off another member here. I put CAC wheels, RC4WD Krazy Crawler tires and RC4WD T-rex aluminum axles on it. Going with a 35t Integy pro motor and Goat 3s esc. |
03-12-2011, 07:03 PM | #2 |
Rock Stacker Join Date: Aug 2008 Location: pittsfield
| boyer
that one sick truck looking good cant wait to see it run in the spring
03-12-2011, 07:35 PM | #3 |
Quarry Creeper Join Date: Aug 2008 Location: Up your tail kicking footballs!
Man that is a sweet ride! You waste no time!
03-12-2011, 07:39 PM | #4 |
Thanks! I like my projects on Saturdays.
03-13-2011, 09:59 AM | #5 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
Looks good, I say ditch the spare though...just my .02
03-13-2011, 10:30 AM | #6 | |
Already done. The 1.9 looked dumb on there. One thing I noticed is that the lower links are mounted to the chassis horizontally and this seems to aid in the axles moving side to side. This might tone down once I put drive shafts in. If not, I will have to make some sway bars for the front and rear. The skeletons are going. They look to small compared to the rest of the truck, they look like newborns are driving it. Last edited by soilwork; 03-13-2011 at 10:33 AM. | |
03-13-2011, 10:45 AM | #7 |
RCC Addict Join Date: Jan 2007 Location: caldwell,idaho
you can always make an L bracket bolt it to the chassis then to the links.looks good .
03-13-2011, 10:52 AM | #8 |
Quarry Creeper Join Date: Sep 2010 Location: Big hands, Little tools.......GRRRRR
Nice ride. For the suspension links, you may be able to use some Tamiya shackle hangers to change the ends to a vertical position. It looks like there may be room to bolt them up inside the chassis, or braze em there. Just a thought. Warwick, as in RI? I'm from Westerly. Let's see some high speed beach runs! |
03-13-2011, 11:18 AM | #9 | |
Warwick, RI Thanks! I have a couple of tlt link and shock mounts that I am going to use. | |
03-13-2011, 01:08 PM | #10 |
Rock Crawler Join Date: Nov 2010 Location: Denver
Awesome rig! |
03-13-2011, 05:24 PM | #11 |
I fixed the side to side play with the axles. My top links didn't have enough of triangulation. I would of never thought of that until a buddy mentioned it to me. Always check the simple stuff first.
03-13-2011, 06:55 PM | #12 |
I was gonna mention that too. It was tight as stick before.
03-13-2011, 08:30 PM | #13 |
All I did was remove the 2 conical washers at the axle mounting points. It only moved the links inward about a 1/8 on each side. I cant believe it made that much of a difference.
