07-05-2006, 02:29 PM | #81 |
Rock Crawler Join Date: May 2005 Location: In front of my comp
Yea, it's gone now. Got a whole new room, and a whole new workbench!
07-05-2006, 02:31 PM | #82 |
Why not just run a different wheel? Much cheaper, or narrow the ones you have.
07-05-2006, 02:31 PM | #83 |
They already are narrowed! If i get a different wheel, Then i need different tires! P.S If anyone has some wheels, with geo's on them let me know! Must be narrowed, or have the wheels not glued!
07-05-2006, 02:33 PM | #84 |
you just cut the inner section off, it doesnt look like you actually narrowed them. Are the tires glued on so hard that you cant get them off?
07-05-2006, 02:37 PM | #85 |
I glued them pretty good. I didn't narrow them, Dez did.
07-05-2006, 03:39 PM | #86 |
Made some progress. Pic's- |
07-05-2006, 04:46 PM | #87 |
Rock Crawler Join Date: Feb 2006 Location: glastonbury
corey it looks good!! id suggest you boil your tires and wheels to get them off. thats probably your best bet...
07-05-2006, 04:46 PM | #88 |
oooooooh and you should be able to lower the ride height and mount the lower links inside on the skid to get you more room...
07-05-2006, 06:10 PM | #89 |
RCC Addict Join Date: May 2006 Location: Aroostook county
Holy Crap Peej Thats Some Great Work On The Frame! Geeez This Makes Me Want A Truck X4 |
07-05-2006, 07:29 PM | #90 |
Think i found a solution. Blackfoot axles! Now where do i get them? EDIT, just ordered a set!
07-05-2006, 09:55 PM | #91 |
Quarry Creeper Join Date: Feb 2006 Location: over there
Lookin good, Corey! Too bad the wheel is gone :( |
07-05-2006, 10:18 PM | #92 |
Quarry Creeper Join Date: Jun 2006 Location: BUILDING A CSC-1 in south mississippi
awsome build i am going to start a scale build with the same chassis
07-06-2006, 09:37 AM | #93 |
Thanks guy's. Its a roller now, just have to relocate my rear shocks. Once i do that ill have pic's!
07-06-2006, 11:50 AM | #94 |
Finished relocating my rear shocks, and lockout for the wheels. Anyway's onto the pics! Gets a good amount of flex! Last edited by CoreyK; 07-06-2006 at 12:05 PM. |
07-06-2006, 11:56 AM | #95 |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
u drunk looks great man glad to see it almost ready |
07-06-2006, 11:59 AM | #96 |
Nah, im just really tired. Ill put better pics up in a few!
07-06-2006, 12:09 PM | #97 |
IMO, the body sits too high. It's your crawler so you can set as high as the body you want it to go. Nice flex ;)...... kitty kitty |
07-06-2006, 12:14 PM | #98 |
corey if you insulate the upper shock mounts with some fuel tubing on either side of the shock youll get more artic in the front... this also eliminates some of the less than stellar sideloaded characteristics of the tlt shocks. the body is cut high because in almost every situation, youll get stuck with the rock rails lower. its a compromise between aesthetics and performance. in this case corey sided with performance in mind. Last edited by peej410; 07-06-2006 at 12:30 PM. |
07-06-2006, 12:14 PM | #99 |
RCC Addict Join Date: May 2006 Location: USA
thats a sweet looking crawler
07-06-2006, 12:34 PM | #100 |
Thanks guy's. And yes, id rather have performance over looks. It will still look good! I mean with that body/frame combo the body can sit 10 feet in the air and still look goood! |
