10-30-2012, 12:47 AM | #1 |
Pebble Pounder Join Date: Mar 2012 Location: Pacific north west
| Toyota Hilux "half cut" TTC build
It had been a while since I received this chassis. I think it's time to start my build thread. It's going to be a 2.2 truck all the parts list as following: Chassis: Custom made from Mattzilla Axles: AX10 axles with longer beef tube, OD/UD gear front and rear Home made stainless steel 4 links front and rear Transmission: RC4WD R2 (was Hot Racing Full Metal Locked Center Transmison) ESC: Holmes BRXL + Integy 35T (will be replaced by Holmes torquemaster 35t) cc BEC Wheel: Gear Head RC 2.2 CAC EZ-Loc Beadlock Wheels Tires: RC4WD Mickey Thompson 2.2 Baja Claw Radio: FUTABA 4PL |
10-30-2012, 12:54 AM | #2 |
| Re: Toyota Hilux "half cut" TTC build
All the parts on table and start the build. This is going to be fun. The longer beef tube and the axles under construction. This thing is really amazing the whole design make the stock AX10 axles 10x time stronger and heavier which also act as a axles weight. Working on the link set up. The WB will be 14 and 1/4. |
10-30-2012, 01:05 AM | #3 |
RCC Addict Join Date: Feb 2011 Location: Huntington Beach
WoW, all the parts. Great start buddy. It's been a while.. |
10-31-2012, 12:06 AM | #4 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
That thing is going to be a beast! Nice looking parts list so far. Can't wait to see it rolling |
11-02-2012, 03:10 AM | #5 |
OK, after two days of cutting, grinding and fitting. Finally she is a roller. Front steering. I use VP chub and knuckle for XR10. And since this going to be a class-3 truck, I figure I will use some advantage of rear steering. Again, chub and knuckle from my XR10. This is the material for my link. Threaded rod from home depot and 1/4" stainless steel tube from K&S also revo rod end. |
11-02-2012, 03:15 AM | #6 |
Took some photo from my backyard. |
11-02-2012, 05:08 PM | #7 |
Pebble Pounder Join Date: Aug 2006 Location: In Da ville
Where can I get those longer beef axle tubes and axles shafts?
11-02-2012, 05:12 PM | #8 | |
| Re: Toyota Hilux "half cut" TTC build Quote:
http://www.rccrawler.com/forum/axles...-0-delrin.html | |
11-02-2012, 05:49 PM | #9 |
If you use longer Beef tube you have to XR10 front universal to replace the stock AX10 shaft.
11-02-2012, 11:09 PM | #10 |
Looks BIG! Do you have any binding on the driveshafts? The angles look a little steep. Also, what shafts are you using? |
11-03-2012, 01:13 AM | #11 |
yes the angle was too steep for RC4WD punisher shaft so I have to go with Traxxas half shaft with metal york for E/T Maxx, it work perfectly. the drivelines work with pins to attach them to the transmission and axle sides. Being all plastic, you cannot use set screws as they would just strip out in the plastic. So these drivelines only work on that have holes drilled through the pinion and transmission shafts. Since I changed the pinion gear to Axial OD/UD gear so there's holes pre-drilled. But the Hot racing all metal locked center transmission did not have holes pre-drilled so I have to give it up and use R2 instead. |
11-03-2012, 11:07 PM | #12 |
Thanks for the info. |
11-06-2012, 12:38 AM | #13 |
Nice, Need update..... |
10-13-2013, 01:56 AM | #14 |
Newbie Join Date: Aug 2013 Location: jakarta
Cool...i wish my rigs will be same..
Toyota Hilux "half cut" TTC build - Similar Threads | ||||
New Build "Navy Cut" prelim shopping list | Orph3o | Axial XR10 | 57 | 05-12-2012 07:56 PM |
1.9 Toyota Hilux crawling at "Lucia Falls, Wa-USA"... | justinart24 | Scale Videos! | 15 | 01-11-2012 12:53 PM |
Tommy R's TTC Build - "Big Oly" | Tommy R | 2.2 Scale Rigs | 825 | 08-30-2011 09:31 AM |
Project***"hawaiian Sun" Toyota Hilux | scale808 | 1.9 Scale Rigs | 26 | 06-16-2009 09:40 AM |
