02-09-2013, 02:34 AM | #1 |
Quarry Creeper Join Date: Dec 2011 Location: Willows
| nor cal rock bouncer "THE HULK"
Here is my southern buggy built by fatboyrs10 dubbed the hulk for the future color scheme. Last edited by minicrawlerguy530; 02-10-2013 at 01:55 AM. |
02-09-2013, 04:11 AM | #2 |
Rock Stacker Join Date: Apr 2012 Location: Whakatane
This looks awesome! What trans is that?
02-09-2013, 09:21 AM | #3 |
Rock Crawler Join Date: Nov 2011 Location: Paradise, ca
| Re: nor cal rock bouncer "THE HULK"
Its an axial scx trans hes beefed up
02-09-2013, 10:36 AM | #4 |
Its beefed, mirrored and flipped.
02-09-2013, 10:58 AM | #5 |
Hows it flipped spur is supposed to face rear of the buggie
02-09-2013, 11:30 AM | #6 |
It is MIRRORED AND flipped
02-09-2013, 11:54 AM | #7 |
First test run with it and this is what happened with a velineon system on 2s with 16t pinion and 87t spur with a horrible drive line angle lol. Last edited by minicrawlerguy530; 02-09-2013 at 12:59 PM. |
02-09-2013, 08:45 PM | #8 |
Rock Stacker Join Date: Mar 2010 Location: spring city
looks like you need to turn you axels up a little bit to get a better line on your drive shafts i cant see it to good in the pics tho
02-09-2013, 09:24 PM | #9 |
Yeah on my front one I did so it hopefully it doesn't happen again. Now either my motor is coming loose or my motor plate too weak and flexing
02-09-2013, 09:56 PM | #10 |
Going Fast Join Date: May 2011 Location: Hazzard County
Good work man! We love those southern buggies |
02-09-2013, 10:33 PM | #11 |
I got the chassis from fatboyrs10.
02-09-2013, 11:34 PM | #12 |
You probally need to double up motor plates
02-09-2013, 11:45 PM | #13 |
I'll get a thicker heat sinked one.
02-10-2013, 01:52 AM | #14 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
| Re: nor cal rock bouncer "THE HULK" As a common courtesy, you should mention who built the chassis in your first post. There are many talented builders on here who rely on referrals for future work to further their talents and sustain quality builds. There's nothing wrong with making it your own, but you need to give a head's up to the followers who will assume you built the chassis yourself. That being said, run with your plan and take it to the next level. Last edited by Bulldog; 02-10-2013 at 01:54 AM. |
02-10-2013, 01:57 AM | #15 |
Ok first post edited with builder and thank you I will continue making it my own
02-10-2013, 08:40 AM | #16 |
Don't bother dinking around with the stock type motor plates they will all come loose. Something like the foff plate from bwd will fix the issue. It uses the 4th screw in the trans and the screws go in from the motor side and have lock nuts rather than the screwing directly into the motor plate. Cool chassis, one of these days I'll get around to building something that sweet. |
02-10-2013, 10:15 AM | #17 |
That sounds perfect and I'm heavy on the throttle lol. And thanks man
02-10-2013, 04:56 PM | #18 |
Well its time for some new axles so I spent more time fiddling with it out on the rocks than driving it.
02-10-2013, 10:46 PM | #19 |
| Re: nor cal rock bouncer "THE HULK" |
02-10-2013, 11:00 PM | #20 |
That's what I'm wanting to do. And my uncle works at a main hobbies and gives me discounts
nor cal rock bouncer "THE HULK" - Similar Threads | ||||
KJ's "The Incredible Hulk" | King James | Large Scale Rigs | 5 | 09-07-2012 03:34 AM |
Go from Losi "Rock Claws" w/ memory foams to HB "Rovers" (pink) w/ Proline Dual Stage | luvmycompax10 | Tires and Wheels | 4 | 01-11-2012 04:13 PM |
