Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: k2 jacked up chevy 454ss
Old 10-09-2006, 03:41 PM   #1
toomanyrcz's Avatar
Default k2 jacked up chevy 454ss
howdy, i started this project about a week ago, i just wanted to try to build a truck with tlt differentials that would look like about a 16" lift on 44" tsls, this is what i came up with...
k2 chassis
this is basically coil type with two polished stock tlt shocks
this is basically finished here, i bought a stupid r/c truck from ToysRus for the body, which i must admit looks pretty sweet, it has a 12" wb, which was perfect for what i wanted to do with it, anyways i will post up a video of it in the next few days.....
toomanyrcz is offline   Reply With Quote
Old 10-09-2006, 03:48 PM   #2
TLTCrawlin's Avatar
what links? I need some 4 my K2 chassis!
TLTCrawlin is offline   Reply With Quote
Old 10-09-2006, 03:54 PM   #3
Im Brandon
Brandon's Avatar
That looks killer! Although I cant see how you are fighting axle sway. Those links look pretty square to the frame. Maybe try a 3 link with a panhard? Most chevy's lifted that high with SAS run that anyways.
Brandon is offline   Reply With Quote
Old 10-09-2006, 04:18 PM   #4
Powered by Awesome
TwistedXT's Avatar
how are you keeping the axles centered under the rig? I dont see any trianglulation or track bar to keep things in check....
TwistedXT is offline   Reply With Quote
Old 10-09-2006, 04:24 PM   #5
That there is gonna have one crazy a$$ draglink!
Robb is offline   Reply With Quote
Old 10-09-2006, 04:30 PM   #6
[HOONIGAN]
Wrecker's Avatar
That is bad azz looking. Let's see some more with the body on.
Wrecker is offline   Reply With Quote
Old 10-09-2006, 04:34 PM   #7
toomanyrcz's Avatar
nluv, i know exactly what you mean, but have virtually none whatsoever, if you look closely at the last pic of the whole truck, you will see big washers on the outside of the rod end, this is because it eliminates the axles from moving left to right, it only allows it to move up and down, you will be able to see it in action hopefully in a few days.....
Old 10-09-2006, 04:40 PM   #8
Thats the Dale Earnheart Chevy body isnt it...I saw it in toys'r us too...Sweet Rig!!
AIPOHAKU is offline   Reply With Quote
Old 10-09-2006, 05:00 PM   #9
toomanyrcz's Avatar
front shot in my chevy:
Old 10-09-2006, 05:09 PM   #10
Im Brandon
Brandon's Avatar
Sounds good man!! I'm glad its working for you. Wait till you crawl with it, hard bodies make things interesting
