02-10-2014, 09:20 AM | #1 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
| Flashpoint 2.2
Tore down my last rig to the axles... |
02-10-2014, 09:24 AM | #2 |
Newbie Join Date: Jan 2014 Location: San juan
| Re: Flashpoint 2.2
Chassis looks real nice what body are you using?
02-10-2014, 09:50 AM | #3 |
| Re: Flashpoint 2.2
***under modification and repair*** ...Then in spring ill be fabbing up some tubing for the rear cage. Body: Styrene Toyota Hilux heavily modified Stock tube from the Wraith, Honcho and custom stuff (Interior cab) Chassis: SCX10 c-channel frame rails Modified bracing (this allowed for widening the chassis) Wraith skidplate Custom front & rear decks (for mounting electronics) Electronics: MMP ESC Spektrum DX3c with SR300 Rx Castle Creations BEC HiTec HS-7954SH High voltage and Torque (steering) Tekin 13.5t brushless motor Transmission & Drivetrain: Alloy case RRP metal gears Axial DIG with HiTec HS645mg servo 32p 58t Spur 32p 9t Pinion Axial wildboar drive shafts (reinforced with steel rod) Axles: Completely built... VP axles VP CVDs VP knuckles VP hubs STRC trusses VP lockers STRC shock & link mounts Axial hardened steel pinion & ring gears Suspension & Steering: Alloy piggybacks White springs (Traxxas i think) 30w silicone oil at all 4 corners Axial alloy high clearance links x4 Axial alloy lower links x4 VP Titanium steering link & drag link Wheels & Tires: Axial 2.2 (from the new Poison Wraith) RC4WD Rock Crusher 2.2 (Backordered) Lighting: VP lightbar VP mount Axial rear brake lighs (not installed yet) So much to do, so little time! :P Last edited by SwampDawg; 02-10-2014 at 11:04 PM. |
02-10-2014, 01:59 PM | #4 |
| Re: Flashpoint 2.2
SCX10 chassis modified & fitment is dead on!! C-frame rails - Paint removed! need bare metal for Tig welding later the spring! (rear cage) Managed to do some electronics along the way too. ESC and BEC located on rear custom bed, LiPo and TRX radiobox mounted (box for Axial NVS, later on...) Soldered on CC 4.5mm goldplated connectors to some 12GA wire off the Tekin motor. Resoldered my CC BEC (not shown in this image) but i slapped on a connector to drop into my PC and program on the fly and another connector which supplies the servo with power&ground. Last edited by SwampDawg; 02-15-2014 at 06:28 PM. |
02-10-2014, 10:46 PM | #5 |
| Re: Flashpoint 2.2
some more progress today... Electronics on rear bed done (Reciever and CC BEC) ESC mounted up front (still needs to be cleaned up) Battery tray still needs to be mounted. Programmed the ESC and BEC (swapped out the brushed for my Tekin) RC4WD bumper mounted. Last edited by SwampDawg; 02-14-2014 at 02:09 AM. |
02-13-2014, 01:00 PM | #6 |
| Re: Flashpoint 2.2
getting very close now!!! everything is put back together but... still needs a few things: Electronics sealed Frame rails need to be painted (much later this spring) means a tear down again. lol Body needs to be finished (camo scheme) Steel cage work (come spring) Removed the yota roof (looked off imo) Removed VP lightbar (wasnt the look i was after) Last edited by SwampDawg; 02-15-2014 at 06:29 PM. |
02-15-2014, 06:15 PM | #7 |
| Re: Flashpoint 2.2
decided to mount up a set of spare C1 running lights i had kicking around. |
02-16-2014, 07:44 AM | #8 |
| Re: Flashpoint 2.2
playing around with ms paint... (simple but not perfect, you get the idea) heres the concept im after when i Tig weld up a tube cage for this rig. Last edited by SwampDawg; 02-18-2014 at 02:21 AM. |
02-18-2014, 02:16 AM | #9 |
| Re: Flashpoint 2.2
installed my custom snorkel and added spot lights. lol and yes...eventually ill deanodizing the purple!! but i needed to use the wraith shock bodies and savage caps to make a better shock. These goofy diaphrams axial gives suck!! HPI has nice o-rings instead. Last edited by SwampDawg; 02-18-2014 at 02:24 AM. |
02-19-2014, 05:07 AM | #10 |
| Re: Flashpoint 2.2
Took some modding but... Wraith interior installed. |
