09-21-2014, 06:50 PM | #1 |
Rock Stacker Join Date: Jul 2014 Location: Brasil
| My version of Axial EXO: Project Crawler/Rock Racer 2 Speed
Hello guys! I would like to share my project: Axial Exo Terra Crawler. My english is bad then I'll use Google translator ok, be patient ... This is the second version of the project, before had put a transmission from RC4WD R2 with DIG and now decided to put the two-speed transmission, RC4WD AX2. I also bought the steering Knuckle's the Axial Yeti to put new aluminum wheels 2.2 " I liked the result, can you cool Crawler and also good top speed ... the best of two worlds Full Specs: ESC: TrackStar GENII 150A - BEC 6v-5A Motor: HobbyWing Xerun 17.5T 1900kV sensored Transmission: RC4WD AX2 2 Speed 60T/15T Radio: Spektrum DX3E + SR300 3 channel 2.2" Aluminum beadlock wheels with Pro-Line Hammer tires 3S Lipo 4000mAh Front and Rear diff's Locked Custom front steering system & rear suspension Pics: Of course, new 3mm aluminum chassis with increased Wheelbase 365mm (334mm is original) and now with better weight distribution. Angles of about 30 degrees Upper chassis to improve stiffness. AX2 Transmission To hold the battery, I used the battery tray the SCX10 Front: For this modification, cut the front tower shock to fit the servo and used to lock the rear camber link. I also cut / sanded the Bulkhead not to pick on the servo arm Axial Yeti steering Knuckle's Rear: I used the front tower shock in rear suspension Partially assembled: Finished: Pics from my previous project: https://plus.google.com/photos/11480...52272627180913 Thanks to all |
09-21-2014, 09:58 PM | #2 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
| Re: My version of Axial EXO: Project Crawler/Rock Racer 2 Speed
That looks pretty cool. How does the higher cg work out? I imagine the increased clearance is nice for getting over rocks. Was it worth the change is cg? Dna |
09-22-2014, 12:05 PM | #3 |
Newbie Join Date: Dec 2012 Location: Auburn
My 2cents, i run the ax2 trans in my ultra 4 car rx8 and pro4 3000kv. When ever rc4wd get the hd output shafts back in stock order it pn z-s0830. Car looks good.
09-22-2014, 06:03 PM | #4 | ||
| Re: My version of Axial EXO: Project Crawler/Rock Racer 2 Speed Quote:
It has also helped wheels that are heavier than nylon ... I will make videos soon to show. Thank you! Quote:
Thank you! | ||
10-01-2014, 04:43 PM | #5 |
| Re: My version of Axial EXO: Project Crawler/Rock Racer 2 Speed Last edited by ACR; 10-01-2014 at 04:44 PM. Reason: add link |
10-04-2014, 03:43 AM | #6 |
| Re: My version of Axial EXO: Project Crawler/Rock Racer 2 Speed |
My version of Axial EXO: Project Crawler/Rock Racer 2 Speed - Similar Threads | ||||
My version of Axial EXO: Project Crawler | ACR | Videos! | 9 | 09-26-2014 03:55 PM |
Axial Crawler Rock Racer | Nicklovin | General Crawlers | 2 | 03-02-2010 09:45 PM |
My Axial AX10 Scorpion RTR Rock Racer/Crawler Video | toecutter | Videos! | 19 | 05-12-2008 04:57 AM |
Axial Scorpion Rock Racer-1/10 Crawler Rtr | PINKY | Chit Chat | 14 | 01-27-2008 06:37 AM |
