09-13-2016, 07:15 PM | #21 |
Pebble Pounder Join Date: Jul 2016 Location: Eugene
| Re: R1cho......scxR10
Any part numbers or pictures of the servo?
09-13-2016, 10:11 PM | #22 |
These ones: http://m.banggood.com/4X-JX-PDI-6221...p-1031156.html I can't say how they'll hold up to something with some speed that can snap housings or gears, but for a slow crawler they may/should do well. #CamBrady2017 |
09-22-2016, 06:00 PM | #23 |
Seriously thinking of building one like this using tko axles
09-30-2016, 02:58 PM | #24 |
Rock Crawler Join Date: Jun 2011 Location: Tifton
I like this I might attempt to do something like this. |
09-30-2016, 06:26 PM | #25 |
I think you need read steer on this, I did it on the R1 and love it! HANG UP AND DRIVE ! |
09-30-2016, 07:56 PM | #26 |
Rock Crawler Join Date: May 2013 Location: Dallas
Just a suggestion, You might want to try internal droop springs, or limiters and stiffer springs. IMO that's really too much flex and the shocks may allow you to bind up/get stuck in cracks compared to a stiffer suspension. I've been in situations with large rocks like in your pics and I've personally found it better to focus on keeping it stable and predictable on 3 wheels and being able to "float" a tire across the gaps.
10-01-2016, 12:06 AM | #27 |
I was thinking about trying some heavier oil out. These shocks are the short 90mm Honcho ones. I have a longer set but I'll need to mount them higher up. I'll likely do a tear down and rebuild soon with a larger spur gear to slow it down some, too. I want to make a wider skid to be able to bring the outboard links inboard because they tend to hang up. Any good source for black delrin or teflon? |
10-31-2016, 09:15 AM | #28 |
Pebble Pounder Join Date: Sep 2013 Location: Santa Cruz
| Re: R1cho......scxR10 |
10-31-2016, 09:16 AM | #29 |
11-02-2016, 01:16 PM | #30 |
| R1cho......scxR10
I took it out today for about 15 minutes worth of crawling this pile. I ordered a set of shocks for it this morning, too. They should be long enough to reach the original mounting point. |
12-17-2016, 11:25 AM | #31 |
| R1cho......scxR10
I mounted the cheap longer shocks and took it out yesterday. It's crawls better, placebo possibly, without carrying a wheel like before. These springs are a little stiffer and I'll change the fluid out when I get a chance. These are, IIRC, GPM rear shocks for a k949. I liked the look of the inboard top mount better. But these clear without touching. It still has crazy flex, bro. Which is a reason for the thicker shock oil. |
R1cho......scxR10 - Similar Threads | ||||
R1cho | Brake Weight | 2.2 Scale Rigs | 3 | 05-02-2016 01:46 PM |
