04-20-2017, 08:33 AM | #1 |
Quarry Creeper Join Date: Apr 2012 Location: Harrisburg
| Bullhead bodied Deuce and a Third
This hare brained contraption was called into existence almost two years ago, and has been on-again/off-again like everything else I've started. With that being said, please don't expect completion or closure. The intent was to build something that was pieced together out of surplus Deuce and a Half parts. Here is the beginning of the end, with a dremel (haggard)cut frame out 3/4" square tube steel, RC4WD transmission, and an unknown turn 12V drill 550 motor : Convenient use of a TX as a ride height gauge: This project was originally going to use a Pro Line 1956 Ford truck body, so the wheel base was set off of it: Once that was figured out, leaf springs made from stainless steel radiator hose clamps: Magnets holding the crudely fabricated shackles in place: And that was as far I made it since I was building this while at a six week school. Boxed up and sent home until it was time to revisit it. Sent from my HTC Desire 626 using Tapatalk |
04-20-2017, 09:14 AM | #2 |
| Re: Bullhead bodied Deuce and a Third
Phase two began with finishing the chassis with stock TF II springs upfront, and taking my time to make better looking shackles: Decent amount of flex, although some of it from the lack of cross members. The decision was made to steal the Bullhead cab from it's intended purpose: Now for a test run in my mother in law's landscaping: The test run was awesome. I decided the cab will stay with this frame, then moved on to something else. Sent from my HTC Desire 626 using Tapatalk |
04-20-2017, 09:32 AM | #3 |
Looks good. What axles are those?
04-20-2017, 10:00 AM | #4 |
Phase three was more recent. After being sidetracked by 1/6th scalers and buying another Wraith, I needed something with leaf springs. Actually, it was SGT Slaughter who suggested it: The body had gone through a round of plastic surgery to make it more proportioned, had exhaust stacks made of 3/8" stainless steel tube, and had a few details added. But for some reason, the wheel base didn't look right. Time for some weldering and drillering to move the rear axle back about an inch. Current electronic set up: AE-2 (Castle)ESC, classified drill motor, big 3S battery, and a noisy Savox servo. Plus I used an old locker hinge for the cab. I also decided to use a set of Mud Slinger XL's instead of the Rock Crushers, I think they suit this build. Enough discussion, on to the action shots on my super secret proving grounds: As with anything, the list of what I want to do is longer than what is done. At least it's operational and shouldn't be cannabolized for something else. Sent from my HTC Desire 626 using Tapatalk |
04-20-2017, 10:03 AM | #5 |
| Re: Bullhead bodied Deuce and a Third |
04-20-2017, 10:32 AM | #6 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
I gotta say I don't like bullhead builds because the body bothers me. Too small just generic enough between Kenworth and peterbilt too. But, I can't put my finger on it yet, but I like this truck. It's simple, you took good pictures of it, and it looks good with the stacks. I like the single axle and single tires. I'd almost leave it like this and send it. Good work. Ben |
04-20-2017, 11:05 AM | #7 | |
| Re: Bullhead bodied Deuce and a Third Quote:
Otherwise, the frame and basic set up staying as is. I'm sort of back and forth as to if I should put a flat bed on it. Who knows... Sent from my HTC Desire 626 using Tapatalk | |
04-20-2017, 11:10 AM | #8 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
A simple flat bed might just set it off nicely. Looks great. Are you still running the r2 trans if so how is it treating you?
04-20-2017, 11:20 AM | #9 | |
I'm still running the R2 and it's working out perfectly. They tend to be on the noisy side since they use straight cut steel gears. It sort of adds to the effect of this truck, like it has a Detroit Diesel in low range. Sent from my HTC Desire 626 using Tapatalk | |
04-20-2017, 11:35 AM | #10 | |
I'm almost done an ascender build them I'm going to set out to build a true 1:10 scale big rig crawler. Just gotta decide which cab I'm going to try and custom fab. I'm an old autocar man and my father and I both have real ones. So my ideal would be to build one but the cabs are pretty curved and such. I'm also a big fan of the GMC Generals and they're very square to I may wimp out and try to build one of those. Who knows. Keep up the good work. Ben | |
04-20-2017, 12:11 PM | #11 | |
I am by no means a "master fabricator" like some of the people on this forum, but the more I experimented with different techniques the more confident I become. That's why I tend to jump around with projects. Nothing ventured, nothing gained. At least that's what I tell myself. An old Auto Car would be a really cool project. There is something about heavy duty trucks from the 1950's through the 1970's. I thought about modifying an Ascender Blazer body into a Brigadier for this, since I have one on an SCX 10. Either way, start a build thread on it. I would like to see it. Sent from my HTC Desire 626 using Tapatalk | |
04-20-2017, 12:25 PM | #12 |
I will start a thread once I get started on it. Need to finish my blazer build first. Check it out in the ascender section. "My little Jimmy lol" is the thread. I'd like to see you make a brigadier from an ascender body! I'm going leaf spring too, going to make my own Hendrickson walking beam rear suspension too. Only thing is axles. I want to stick with ascender axles because I already know how to widen them, the tricks to building them etc etc and have plenty of spare parts. Like to keep my trucks with same components for ease of maintenance. But after seeing the top loader axles you're running, they make a huge difference in appearance. But the price tag on them is very steep and still only wide enough for a bullhead body or 1:10 pickup. I'm going to run legit 1:10 width big rig axles, 10 tires straight frame, the whole deal. But make it set up for trailing/rock climbing. Not like a road tractor. Ben |
04-20-2017, 12:45 PM | #13 |
04-20-2017, 01:17 PM | #14 |
I'll have to check out your build. To get a Brigadier out of a Blazer would be a lot of work. My plan was to to make mold of the Blazer and cast it in resin, so I would have hard plastic to work with. But that may or may not happen. I'm trying to convince my better half that we need a 3D printer so I'm not in the basement hours on end scratch building things. Yes, the Blackwells are not cheap but they are functional double planetaries like real Rockwells and they're geared much better at 3.75:1. And they're wider than 1/10th axles, 7.56" hex to hex compared to 7.19" pin to pin. Sent from my HTC Desire 626 using Tapatalk |
04-20-2017, 01:19 PM | #15 | |
| Re: Bullhead bodied Deuce and a Third Quote: Sent from my HTC Desire 626 using Tapatalk | |
04-20-2017, 02:56 PM | #16 |
Quarry Creeper Join Date: Nov 2015 Location: Walkerton
Just stumbled upon this thread. Glad to see the good ole Bullhead back again. One of these days you're gonna finish this build lol. Looks great as always. Sent from my VS995 using Tapatalk |
04-20-2017, 03:25 PM | #17 | |
Bullhead bodied Deuce and a Third - Similar Threads | ||||
looking for a deuce | cameraman | Paint and Body | 0 | 01-29-2012 07:22 PM |
J.E.E.P XJ # deuce now with 1.5s | 1BadJeepBruiser | 1.5 Scale Rigs | 112 | 01-03-2010 11:19 AM |
Bullhead? | cartronicshn | Tamiya Clod Buster | 7 | 07-08-2006 10:15 AM |
