07-27-2018, 02:45 PM | #1 |
Quarry Creeper Join Date: Aug 2015 Location: Ontario
| BrassMonkey2018
Dispite this rig being finished. My laziness set in and I am finally making the build thread. So with my latest build I set out to push the envelope of scale as far as I could and still be legal with -50 points when I was done. I knew class 3 was the class I wanted to build for. So I set off. I started with a set of losi axles and a bunch of dlux bits and pieces. I really love the asemtrical moon buggy style tubers you see in a WEROCK style competition. So I am using those as inspiration. Sent from my SM-N950U using Tapatalk |
07-27-2018, 02:50 PM | #2 |
| Re: BrassMonkey2018
I have a friend who has a very specialized metal tubing I used to build the chassis. Remember I wanted to keep this at -50 but dont want it to be a hog in the weight department. I decided cms was a good way to go Since I am using losi axle (as always) nothing is easy and I needed to make a panhard mount for the axle. I decided after looking at alot of moon buggies I would make the mount on the axle raised. (Because math not meth) Sent from my SM-N950U using Tapatalk |
07-27-2018, 02:57 PM | #3 |
| Re: BrassMonkey2018
Once I got the tube chassis started I had to adhere to the specs for height width and so forth. There is no min or max spec for boatsides currently. Also I needed to figure out a cms placement that would be conducive for the no bumper moonbuggy style steering I've seen. Sent from my SM-N950U using Tapatalk |
07-27-2018, 03:00 PM | #4 |
| Re: BrassMonkey2018
Once I had the front together I had to take lots of pictures of it because I was amazed I made it this far with it. I ordered some more goodies from dlux and then back to taking photos. Sent from my SM-N950U using Tapatalk |
07-27-2018, 03:04 PM | #5 |
| Re: BrassMonkey2018
Also above is a rare glimpse at my custom transmission and my custom team brood motor. 900kv 550 can sensored brushless 5mm output goodness. (If I haven't mentioned it yet insert team brood commercial here) Sent from my SM-N950U using Tapatalk |
07-27-2018, 03:08 PM | #6 |
| Re: BrassMonkey2018
I finally figured out the rear of the chassis and I had a good friend over at precision make me this custom tiny servo winch from a wing servo for a glider. And I got to throw the chassis on a scale and see where it weighed out at so far. Sent from my SM-N950U using Tapatalk |
07-27-2018, 03:14 PM | #7 |
| Re: BrassMonkey2018
So far I have -8 full tuber -5 cms -3 metal sliders -3 rear bumper -2 integrated shock mounts And it's under 9oz. Time to figure out a body. The rules state a spec for thickness and material and as such I followed them in a attempt to get -12 full hard body and a additional -4 for scratch built. I knew I needed to be careful not to end up with panel points. Sent from my SM-N950U using Tapatalk |
07-27-2018, 03:21 PM | #8 |
| Re: BrassMonkey2018
The body started to take shape along with the interior cover and inner fenders. The weight at this point was 12.10oz chassis and body. Jeep ish was what I was going for since in class 3 your encouraged (but not required) to make it look like a known 1:1 so much mike nascar or again WEROCK fiberglass bodies I think I nailed it. Sent from my SM-N950U using Tapatalk |
07-28-2018, 01:00 AM | #9 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: BrassMonkey2018
Gorgeous work so far documented. Can't wait to see the end result.
07-28-2018, 04:20 AM | #10 |
Quarry Creeper Join Date: Jan 2011 Location: Woody point
| Re: BrassMonkey2018
very nice tube work there
07-28-2018, 09:25 PM | #11 |
Rock Stacker Join Date: Jan 2016 Location: NorthBay, Ca
| Re: BrassMonkey2018
Yeah, I like the metalwork. It looks like stainless. How about a sneak peek at the finished rig? |
08-01-2018, 05:13 PM | #12 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
| Re: BrassMonkey2018
Nice to see guys using losi axles still. |
08-16-2018, 08:59 PM | #13 |
| Re: BrassMonkey2018
Heres a sneak peek at the finished product. Sent from my SM-N950U using Tapatalk |
08-18-2018, 06:36 PM | #14 |
| Re: BrassMonkey2018
That's a nice looking rig! Thanks for the peek!
08-19-2018, 09:31 AM | #15 |
| Re: BrassMonkey2018
It went to the scale nationals in TN this year. -50 points on a class 3 under 6lbs and no interior or driver. It took alot of planning. Sent from my SM-N950U using Tapatalk |
