01-15-2008, 12:45 AM | #1 |
Quarry Creeper Join Date: Jun 2007 Location: bay area
| traxxas big bore?
anyone using them on the edge? i was going to but i think there a little to short... i want to run semi droop so please give me feed back! i really don't want to run stocks either... get back to me please!!!
01-15-2008, 01:06 AM | #2 |
Newbie Join Date: Nov 2007 Location: Seattle, WA
The big bores are a little short, the trick is take the shock shafts out of your stock shocks and put them in the big bores.
01-15-2008, 01:14 AM | #3 |
01-15-2008, 02:18 AM | #4 |
Rock Stacker Join Date: Oct 2007 Location: Devon, UK
See my build. They fit perfectly. |
01-15-2008, 08:00 AM | #5 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
01-15-2008, 11:15 AM | #6 |
even set as droop?
01-15-2008, 02:46 PM | #7 |
I used the axial shock shaft and piston straight out of the stock shocks. You will need to use the Traxxas shock ends because the shock spring retainers are a different diameter then axial. I'm not setup as droop, so can't help you there, but it should work the same. |
01-15-2008, 03:06 PM | #8 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
