01-20-2008, 06:49 PM | #1 |
Newbie Join Date: Dec 2007 Location: Winfield
| Which Shocks for AX10??
Looking for recommendations for which shocks to use to replace the stock shocks on my Scorpion??
01-20-2008, 06:53 PM | #2 |
Quarry Creeper Join Date: Sep 2007 Location: Carlisle
01-20-2008, 07:02 PM | #3 |
Pebble Pounder Join Date: Jan 2008 Location: Rancho Cucamonga
heres some as well: http://www.tcscrawlers.com/Integy-MS...N-p-16715.html they are integy MSR10 you can use the RC18T REAR springs in them too ;) |
01-20-2008, 07:39 PM | #4 | |
Rock Crawler Join Date: Apr 2007 Location: APPLE VALLEY,CALIFORNIA
01-20-2008, 09:16 PM | #5 |
Newbie Join Date: Sep 2006 Location: Bremerton
I've had good luck with them. I'm running them with the RC18t silver springs, 4 hole piston and 30wt oil. They seem real smooth and consistant on the rocks. I like the fact I can swith to droop and run the longer rodends that come with them and still maintain good groud clearance
01-20-2008, 09:24 PM | #6 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
I like my Hot bodies T-maxx shocks
01-20-2008, 10:25 PM | #7 | |
well i thought my shipments would of came in on friday they didntso i cant run the truck yet so i dont know the performance yet. but i did change over to the rc18t rear blue springs front and rear with the 3 hole piston, it rebounds a bit slow so i may switch over to the 4 hole piston. but since i took out the stock hard springs it articulates much better. they feel smooth and i have no leaks been pushing up and down on them a lot. | |
01-21-2008, 05:50 AM | #8 |
Rock Stacker Join Date: Jan 2007 Location: Lincoln
Anyone using internal springs in the stock shock bodies? How is that working out?
01-21-2008, 07:28 AM | #9 |
Rock Stacker Join Date: Aug 2007 Location: Switzerland
Maybe a stupid question. But I am new to crawlers so I am a bit curious. Why change the stock shocks in the AX10? Are they bad? |
01-21-2008, 09:03 AM | #10 |
I joined the Band! Join Date: Aug 2007 Location: i cant remember
01-21-2008, 11:10 AM | #11 |
Pebble Pounder Join Date: Jan 2008 Location: Mission B.C. Canada
Im running stock shocks that work great, but I had to customize them a bit to do it. Put 3/8 diam 3/4" long soft springs inside under the piston and run axial white front and green rear springs outside, stock internal disk dampers and 30 wt oil. Also added 1/4" spacers bettween the shock rod ends and spring cups to limit uptravel a bit and add a bit off preload. Rear shocks and links are mounted 1/4" further outward on the axle end. Upper links lengthened to 70mm with relocated mounting holes on the frame. Tires have 3 oz stick on wieght each. With this set up my lower links are 100% horizontal at ride height I have about 3/4" of uptravel and 1/2" of droop as well as barely any torgue twist. Would like to find some threaded alum shock bodies the same length as the stockers and I think it would be perfect |
