01-22-2008, 03:35 PM | #1 |
Newbie Join Date: Dec 2007 Location: Olympia
| Do these mods help?
Newbie here. I have seen a lot of mods for the axial on here. I wanted to know if moving the lower links inward help in the articulation at all or is that mod only to help so the tires dont rub on them and to move the upper nut inwards so it doesnt catch on stuff. does it still twist the same or does it make it better or worse for stability. does moving the shocks outward help do anything? another question also is the differnt plates you can buy to mount servos and the upper tri link to. what does that do? is that because the bolt can pull out of the axle? or does that help anything? hope these questions make sense. any help would be apriacated. thanks |
01-23-2008, 09:59 AM | #2 |
Bump
01-23-2008, 10:10 AM | #3 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
Yes they do You need to do a little searching on link setups. Do a search in the tech sections:link configuration,4 link set up,verticle seperation,squat,anti squat and roll center. 3 link VS. 4 Link |
01-23-2008, 10:35 AM | #4 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Try it...its a quick change. Worse case you quickly change it back. This forum is filled with information and with the advent of the AX-10 people just ask repetitive questions. The seasoned vets with all the info will grow tired of answering the same questions all the time. |
