Thread: Do these mods help?
Old 01-22-2008, 03:35 PM   #1
Default Do these mods help?
Newbie here.
I have seen a lot of mods for the axial on here. I wanted to know if moving the lower links inward help in the articulation at all or is that mod only to help so the tires dont rub on them and to move the upper nut inwards so it doesnt catch on stuff. does it still twist the same or does it make it better or worse for stability. does moving the shocks outward help do anything?
another question also is the differnt plates you can buy to mount servos and the upper tri link to. what does that do? is that because the bolt can pull out of the axle? or does that help anything?
hope these questions make sense. any help would be apriacated. thanks
IB14A69 is offline   Reply With Quote
Old 01-23-2008, 09:59 AM   #2
Bump
Old 01-23-2008, 10:10 AM   #3
ghetto fabulous newbie
Yes they do You need to do a little searching on link setups. Do a search in the tech sections:link configuration,4 link set up,verticle seperation,squat,anti squat and roll center.
3 link VS. 4 Link
yotachump is offline   Reply With Quote
Old 01-23-2008, 10:35 AM   #4
binaryterror's Avatar
Try it...its a quick change. Worse case you quickly change it back.
This forum is filled with information and with the advent of the AX-10 people just ask repetitive questions. The seasoned vets with all the info will grow tired of answering the same questions all the time.
binaryterror is offline   Reply With Quote
