02-05-2008, 09:15 PM | #1 |
Quarry Creeper Join Date: Jan 2008 Location: pittsburg
| stupid questions about droop
i recently ordered the stage 2 kit from ckrc and have been looking at the build for it. in it they put the bumpstop inside of the shock body. i was wondering if this is like a droop setup? because i was thinking about just replacing the bump stop with some shock springs from a micro t, i have a ton of different stiffnesses and they would serve the same purpose is this a good idea.
02-05-2008, 11:11 PM | #2 |
Quarry Creeper Join Date: Mar 2007 Location: winchester
so your talking about running small springs inside the shocks that would double as a bumpstop. i guess if the springs fit then that would be optimal. it'd give you a little bit of ride height also right.
02-05-2008, 11:30 PM | #3 |
Rock Crawler Join Date: Apr 2007 Location: portland
on the outside? thats not droop. It would be just like a stock coilover but the spring would only go to the bottom of the shock body. Droop is where the spring is on the inside of the shock body, under the piston and it limits down travel instead of up travel.
02-05-2008, 11:50 PM | #4 |
02-06-2008, 12:14 AM | #5 |
Pebble Pounder Join Date: Dec 2006 Location: uk
i run the internal spring and no bump stop but use a spring from a mardave v12 on top of the piston aswell which gives me about 6mm more ride height (drive shafts nearly level)
02-06-2008, 12:32 AM | #6 | |
| Quote: | |
02-06-2008, 02:51 AM | #7 |
thanks for the response. but that picture is exactly what i needed. what spring is that?
02-06-2008, 03:40 PM | #8 |
Newbie Join Date: Mar 2007 Location: SPAIN
Hi, what is the benefit of this technique? ( sorry my english) |
