Thread: steering
Old 02-21-2008, 03:19 PM   #1
Default steering
ive just built my ax10 and ive only got the front steering set up at the moment. The truck seems to have a rather large turning circle for a truck ment for rock crawling and compared to other types of models that I have with a simular wheel base.I havent ran it on the rocks yet.my question is is this because the diffs are locked or have got another problem/ the servo seems to be functioning correctly
madforRC is offline   Reply With Quote
Old 02-21-2008, 03:28 PM   #2
Yep it is the locked diffs
Jonnie Fraz is offline   Reply With Quote
Old 02-21-2008, 04:45 PM   #3
I joined the Band!
yep thos dand diffs how stupid lol jp
your truck if working right
Alex35 is offline   Reply With Quote
Old 02-21-2008, 05:25 PM   #4
if you want an insanely sharper turning radius for technical rock crawling, then you need front dig. take ten minutes searching you tube to get an idea how it performs. the r2d is a popular tranny with dig already setup for you. if you would like to find more info, there are tons of posts on how to make your own homemade versions on the forum. use your search skills
mtnyote is offline   Reply With Quote
Old 02-21-2008, 05:31 PM   #5
Definitely because of the locked difs.Like Mtnyote said you can search for an r2d dig setup..or check this out..new and nice!
Dig anyone??? Its Here!!!!
Nacho is offline   Reply With Quote
