02-09-2008, 11:55 PM | #1 |
Quarry Creeper Join Date: Oct 2007 Location: vista - san diego
| crooked axal
iv had my ax10 for a long time so im not a newb at figuring all the little things out that go wrong, but i cant figure this one out one of my axals is crooked i made sure all of my rod ends on my links are tight checked the shocks everything and i cant get it, and when im crawling it pulls back really far and i will stop it when its in the really crooked posision and i cant see what is wrong.. o ya and its the rear axal hope someone knows thanks
02-10-2008, 12:06 AM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Got any pictures of whats happening?
02-10-2008, 12:11 AM | #3 |
Rock Stacker Join Date: Oct 2007 Location: Yakima
Is it still the stock chassis with the 3 link setup? If so I found that to be pretty typical with mine. I went to the 4 link plates from TCS on both ends and it all but eliminated axle walk for mine. The only other thing that comes to mind is a silly but necessary question......did you mount the links in same holes on the sides of the chassis? Meaning that there are many holes to choose from, did you maybe get the 2nd hole on one side and the 3rd on the other,etc. Just my 2 cents. Cheers! |
02-10-2008, 12:15 AM | #4 |
Pics would be very helpful to see what's going on. |
02-10-2008, 04:34 PM | #5 |
Rock Stacker Join Date: Dec 2007 Location: paso robles
my guess is you have bent links? i bet one of your bent links is "BENT" making your rear axel crooked |
02-10-2008, 06:23 PM | #6 |
Rock Crawler Join Date: Nov 2007 Location: San Bernardino
02-10-2008, 06:27 PM | #7 |
Rock Crawler Join Date: Oct 2007 Location: richmond, va
try making your links in a double trianglated set up. like this > < |
02-10-2008, 06:33 PM | #8 |
Rock Crawler Join Date: Aug 2007 Location: Tucson
If you are running the high clearance links which are prebent and you got in a good bind you can bend one with the throttle. Are you running bent links? Compare them side to side with each other. Might be the problem
02-10-2008, 07:22 PM | #9 | |
i am running bent links and i was thinking that could be the problem thanks i will check | |
02-11-2008, 07:02 PM | #10 |
I Watched One Of Our Guys Fold One At Our Comps And Did It Look Goofy. It Bent About Another Five Deg Or So.
02-11-2008, 10:18 PM | #11 |
Newbie Join Date: Jan 2008 Location: Morgantown Wv.
That happened to me... it was a bent bent link... Here is a video of what it looks like. It happens after the first crash... About 1 min in to it. http://www.youtube.com/watch?v=SH7LzyauIRU |
02-12-2008, 10:29 AM | #12 |
Rock Stacker Join Date: Jan 2008 Location: westminster
your links are probably bent. it happened to my car.
