02-14-2008, 09:35 PM | #1 |
Pebble Pounder Join Date: Jan 2008 Location: las cruces
| battery question
just for the record, i have used the all mighty search button and came up with nada. my question is, will the AX-10 stock electronics stand up to a 3600 lipo battery?
02-14-2008, 09:47 PM | #2 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
02-14-2008, 10:00 PM | #3 |
basically whatever voltage i can get away with. its comes with a tazer esc. its kit A from CKRC.
02-14-2008, 10:20 PM | #4 |
Rock Crawler Join Date: Dec 2007 Location: Ventura, Ca
Operation ................................. Proportional forward, proportional reverse with braking delay Input Voltage ............................ 4-cell (4.8 volts) to 7-cell (8.4volts) DC Peak Current ............................ 700 amperes Continuous Current ................. 110 amperes Full-On Resistance ................... 0.006 ohms Frequency ................................ 2 kHz BEC output ............................... 4.8 VDC, 1 amp max. Overload Protection ................. Thermal Dimensions .............................. 1.57 x 1.57 x 1.06” (40 x 40 x 27mm) Weight ...................................... 1.80 oz. (52g) Looks like your limited to 8.4 volts and it only has a 1amp bec at 4.8 volts. Mah doesnt matter, but your gonna have to keep to a 2s lipo........ |
02-15-2008, 10:29 AM | #5 |
The Higher Mah the longer run time you have. For a 2.2 1500Mah is enough.
02-15-2008, 10:51 AM | #6 |
Newbie Join Date: Feb 2008 Location: quebec
you run for how much time aproximatly?? beacause 1500 its not a lot i think i'm plaining to run something like 2400 or more
02-15-2008, 10:52 AM | #7 |
50min
02-15-2008, 10:57 AM | #8 |
Quarry Creeper Join Date: Dec 2007 Location: OP KS
I ran a Tazer for a while, but could not put up with the glitching and reverse delay. I know this doesn't help you, but heads up when you start experiencing this.
02-15-2008, 11:49 AM | #9 |
ok, so stick with a 2s lipo. any suggestions on where to get some. as you all probably know im new to all of this so any help would be greatly apprieciated.
02-15-2008, 11:53 AM | #10 | |
so this is what i found... will it work and how do i put my own plug on it? Cell Count: 2S - 7.4 volts. Capacity: 2200mah Pack Plug: None (You will need to add your own connector) Tap Style: Align Tap | |
02-15-2008, 11:58 AM | #11 |
02-15-2008, 12:32 PM | #12 |
RCC Addict Join Date: Nov 2007 Location: Nine Mile Falls, WA
Go hear and "Click" on the Axial link. http://www.maxamps.com/categories.php?cat=13 You should also see this mentioned in the Owners Manual for the new RTR Axial kit. Jason |
02-15-2008, 12:45 PM | #13 |
02-15-2008, 12:54 PM | #14 |
It's not hard, and I think if you get it from cheapbatterypacks.com they can solder them on there for you for a little extra coin.
02-15-2008, 12:54 PM | #15 |
If you go to the link I showed you you can order your packs with whatever main plug you need and what ever balance tap you need we install them for you no need to solder anything. We also carry the full line of Hyperion Chargers look at the Hyperion EOS0606i AC/DC With the Balancer built into it. Jason |
02-15-2008, 01:39 PM | #16 | |
02-15-2008, 01:46 PM | #17 |
I'm not sure which main connector will be on the RTR But a good guess would be the Tamiya style. I would replace it with a better quality Deans Ultra and order your packs with them on it. The Problem with the Tamiya plug is they aren't very efficient the deans are a zero loss connector and will provide better power transfer from the pack to the esc. We also sell the connectors so you can order one to change out the tamiya one on the esc. Jason |
02-15-2008, 01:51 PM | #18 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
If you are new to LiPo, I would make the investment into an ESC with voltage cutoff. It can get messy if you drop the voltage too much. Also remember that you are going to have to invest in a LiPo charger also. |
02-15-2008, 01:56 PM | #19 |
Yes that's right if you go Li-Po you'll need an LVD or LVC like these: http://www.maxamps.com/products.php?cat=19 The charger I mentioned already is a great unit. Jason |
02-15-2008, 02:47 PM | #20 |
