02-22-2008, 09:16 AM | #1 |
Rock Stacker Join Date: Feb 2008 Location: THE IDAHO PAN HANDLE
| Aluminum Transmission Outdrive!!??
I have noticed on my ax10 that the yolks connected to the outdrive shaft are coming loose all the time... I make sure to always use thread lock, and every time the yolks are loose, the set screw is NEVER loose... After closer inspection the end of the output shaft (part# AX30404) has a dimple in it from the set screw which is causing my looseness... Does any one else have this problem??!! Is there a hardened steel version somewhere out there? Looked on Axials site and didnt see one. Why is this part not steel?
02-22-2008, 09:23 AM | #2 | |
02-22-2008, 12:40 PM | #3 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
Mine has a dimple too... that sounded weird... but yeah I just make sure the screw seats in to the dimple. IT has to be lined up perfectly with the flat face of the output shaft or it will slip. On a side note, once I ditched my crappy allen wrench for a Ti-Ni Integy allen driver, I could actually tighten it down 3 times more than with the crappy ones without stripping the screw or pinion. No locktite, 20 or so HARD runs, not once did the shafts pop loose.
02-22-2008, 02:12 PM | #4 |
Rock Crawler Join Date: Dec 2007 Location: Ventura, Ca
Hmmmmm Maybe one made from titanium would be a good thing? Maybe in different lengths as well, you been reading my mind? Stay tuned.......... |
02-22-2008, 02:21 PM | #5 |
yes Ti would be good too |
02-22-2008, 03:14 PM | #6 |
Quarry Creeper Join Date: Jan 2007 Location: I live in my own world,they know me here
Trading for Stampede yokes and driveshafts also solves this problem
02-22-2008, 04:10 PM | #7 |
yolks and drive shafts have nothing to do with the outdrives IN the transmission...;)
02-22-2008, 04:34 PM | #8 |
Rock Stacker Join Date: Aug 2007 Location: Calgary
02-22-2008, 05:05 PM | #9 |
