02-23-2008, 09:35 PM | #1 |
Pebble Pounder Join Date: Jan 2008 Location: Oak Harbor
| Battery question
Would I be able to fit 3 sub-c cells on either side of the servo on front axle? This would be with the tcs battery plates I am thinking that the cells would fit best if they were in a brick configuragion (triangle) and with the cells pointing up and down. Thoughts?
02-23-2008, 10:08 PM | #2 | |
Rock Stacker Join Date: Jan 2008 Location: Connecticut
We tried it and they rubbed....Couldnt fit them no how. Ended up going with six 2/3 cells on the axel plates. | |
02-23-2008, 10:11 PM | #3 |
02-23-2008, 10:12 PM | #4 |
Rock Stacker Join Date: Oct 2007 Location: Taranaki
Use a 2S 800 mah lipo.
02-23-2008, 10:19 PM | #5 |
no lipo; I dont have a lipo charger and would wrather spend the extra money for lipo stuff on my new savage x ss! (ie "Dang! I need more fuel"
02-24-2008, 12:29 AM | #6 |
02-24-2008, 08:07 AM | #7 |
Quarry Creeper Join Date: Dec 2007 Location: Chester VA
| If your dead set on the bigger cells you can just make up your own pack and wrap it over the servo or however it works best. I would just stick to the 2/3a and maybe get it in a 7 or 8 cell config if your charger can handle that many cells and your looking for more runtime tho the 2/3's give plenty of runtime for crawling imo |
02-24-2008, 08:18 AM | #8 |
RCC Addict Join Date: Nov 2007 Location: Nine Mile Falls, WA
Go with an 8 cell of IB 1400's or even a 10 cell pack like I did. We do custom packs but all you pay for is the cells and hardware no charge for the pack construction. Check us out. www.maxamps.com Jason |
02-25-2008, 09:35 PM | #9 |
My understanding is that more cells means more power and less runtime? FYI; my charger has a max of 7 cells and my esc has a max of 6 cells so I have to stick with a 6 cell
02-25-2008, 11:06 PM | #10 | |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
1)more cells = higher voltage = more power 2)maH = run time 3)get a new esc and charger. here is what i have battery : http://www.maxamps.com/Lipo-2100-111-Pack.htm charger: http://www.maxamps.com/Eos6i-AC-DC.htm esc: http://www.castlecreations.com/products/sidewinder.html do some reasearch and see how much you want to get into crawling. | |
02-25-2008, 11:06 PM | #11 |
Pebble Pounder Join Date: Jan 2008 Location: Woodinville, Washington
If I were you, i'd take an older, not much used battery, cut it up into individual cells, and lay 4 across the top of your servo, and then 2 on the sides of your servo, thats what i did, works like a champ. It is heavier than 2/3 cells though, but just take some weight out of your wheels or there is your wheight instead of wheel weights.
04-16-2008, 01:13 AM | #12 |
Rock Stacker Join Date: Jan 2008 Location: Lexington
Alright guys 3 questions: 1) Is there a lipo saddle pack that will fit on the ckrcc battery plates on the front axle? 2) I am considering doing away with the battery plates on the front axle and going with axials battery/servo tray and mounting a lipo that way. Which lipo do you recommend in this configuration? 3) Would 4 or 6 cell nimh 4200's pack be too much weight on the front end? I have heard you want and try to keep the rig as light as possible. You will have to excuse me I am new to lipos and know nothing about them. Thanks for the help Last edited by BMAC; 04-16-2008 at 02:20 AM. |
04-16-2008, 08:34 AM | #13 |
The only Li-po saddle pack that will fit on the front plates is this one: http://www.maxamps.com/proddetail.ph...dlePack&cat=82 This link will show you what will fit on the Axial optional tray: http://www.nitrokillers.com/showthread.php?t=1135 and stick with 2/3rd cells on the front if you go the NimH route we have those available also. Jason |
04-24-2008, 12:50 PM | #14 |
Newbie Join Date: Apr 2008 Location: Denver
Okay i cut up an old 7.2 battery pack to do the same thing but i lost the paper that i wrote everything down on as fas as the wiring pattern so now i need help. help on wiring it all together agin, any help would be great!! thanks 1807nicholas |
