02-26-2008, 11:50 AM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: Hudson
| Front SERVO relocation PLATE question Someone who has one please read
Hello I am thinking of possibly mounting my Lithium battery on the front axle using the Axial front mount servo plate for neatness. my batteries Dimensions (cm):7.3 x 3.6 x 3.3 I would like to know how much surface area is next to the servo for mounting Lithium batteries.? can you help and just measure yours if you have one? CM or Inches is fine please thank you |
02-26-2008, 12:05 PM | #2 |
Rock Stacker Join Date: Feb 2007 Location: bristol
i dont have my truck in front of me right now but off the top of my head ild say 4'' by 2'' i have a 1000 mah lipo mounted on mine and it fits the space perfectly
02-26-2008, 12:58 PM | #3 |
Maybe later when you are aound your truck you can measure it quickly and post another reply? let me know |
02-26-2008, 02:05 PM | #4 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
I'm in the same boat as the last guy, but I use the Vislero 3s 1300mah lipo pack available from cheapbatterypacks.com (I got mine from Holmes) and it is a great fit. Check out CBP, as this pack is about the biggest I'd put in that spot, and the site should have the measurments.
02-26-2008, 02:09 PM | #5 |
Rock Crawler Join Date: Jan 2008 Location: Knoxville
specs on the Pack I am running (same pack as M.S.); Pack Size: 20mm x 35mm x 68mm just fits so I am thinking this should help |
02-26-2008, 02:12 PM | #6 |
Quarry Creeper Join Date: Aug 2007 Location: United States
I have the plate on mine and I am running this: 47mm x 18mm x 70mm http://www.commonsenserc.com/product...roducts_id=212 It is a tight fit but it fits with no rubbing. |
02-26-2008, 02:13 PM | #7 |
RCC Addict Join Date: Nov 2007 Location: Nine Mile Falls, WA
We've got this 2000 in a 3S or 2S and on the front servo battery tray it's only 4mm longer than the battery area on the tray. It does work. http://www.maxamps.com/proddetail.ph...ro-Pack&cat=82 Jason |
02-26-2008, 02:26 PM | #8 |
Pebble Pounder Join Date: Jan 2008 Location: Rancho Cucamonga
yes the vislero is the biggest one you can put on there the dimensions are 7cm Length X 3.5cm width x 2cm height. you can play with the height of the batt but 7cm is the max before you will hit the whel when turning heres some refrence pics for you : |
02-26-2008, 04:20 PM | #9 |
Hi again ok great thanks for the measurments. I also have a Lipo that measures Dimension: 64mm X 31mm X 18mm that one maybe my best bet! thanks for the photo shots of the battery plate with lipo attatched. how do you like it? its just a little higher than mounting saddle packs what do you think of it? |
02-26-2008, 08:23 PM | #10 |
It rules. Having gone with 11 volts I'll never go back. The wheelspeed allows me to run right up stuff I couldn't get up before. Huge difference from my stick packs mounted up high. Do it.
02-26-2008, 08:32 PM | #11 |
well i like it a lot! because lipos dont weight anything its ok its a tiny bit higher than a sadle pack. the only downfall to mounting any batt on the axle is it might get damaded on a roll over ect. other than that i like it a lot |
02-26-2008, 09:21 PM | #12 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Don't forget that the offset of the wheels you are running is going to make a difference too. |
02-26-2008, 11:04 PM | #13 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
i just bought the max amps 3 cell 2100 lipo and it is AMAZING. runtime and POWER are OUTSTANDING. i cant stress this enough. i will never run another battery. here is the link http://www.maxamps.com/Lipo-2100-111-Pack.htm @ 34mm X 98mm X 24mm its too big to mount over the front axle, but i like that better because then it is protected from roll-overs. THIS BATTERY IS AMAZING |
