03-02-2008, 02:15 PM | #1 |
I joined the Band! Join Date: Dec 2007 Location: cotati
| axial + rock rider chassis
i would like to see other rock rider chassis's on axial axles I'll start here is mine since the this picture i have added full droop in front sprung in rear w/ losi yellow springs spektrum dx3.0 radio ( any one do 3 position dig set up with this radio?????) i now have 2 1/8 belly clearence thanx Last edited by nuts5000; 03-02-2008 at 02:17 PM. Reason: add text |
03-02-2008, 07:35 PM | #2 |
RCC Addict Join Date: Aug 2007 Location: Rohnert Park
03-03-2008, 12:59 AM | #3 | |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
| Quote: | |
03-05-2008, 08:45 PM | #4 |
Pebble Pounder Join Date: Dec 2004 Location: South Lyon
| I might have to got to full droop, ride height is a little high with big bores...Ideally I'd like to find some springs that allow 1/2 uptravel &1/2 downtravel... Last edited by diesel72; 03-05-2008 at 08:55 PM. |
03-05-2008, 10:34 PM | #5 |
Quarry Creeper Join Date: Jan 2008 Location: pittsburg
im currently running the 1/2 and half suspension, a good cheap way to buy the springs is to buy team losi mini-t front springs. they fit perfectly. just buy 2 sets. i got each set at my LHS for $5 a piece
03-05-2008, 11:21 PM | #6 |
Quarry Creeper Join Date: Aug 2006 Location: Baumholder
Very nice looking rigs that both of you have. I was looking at that chassis from RC4WD but then I seen the Copperhead and I think that is the on that I will get. Also on the droop setup I read in another post that somebody used the springs out of a BIC pen. the just put the spring over the shaft on the inside and said that it works perfect.
03-06-2008, 08:34 AM | #7 |
rcp makes internal springs for full droop i have them in the front shocks and 1/2 droop in rear with losi yellow springs the shock mounts are really weak and thin on this chassis i have about 2 1/4 of belly clearence diesel72 looks great but you need to get it closer to the ground my first picture it has about 2 5/8 belly clearence i have since lowered it a little more and a lot of lead weight keep the pictures comming and i will do the same thanx |
03-06-2008, 09:23 AM | #8 |
a few new pic you will notice the brass front shock mount that is a quick fix for the poor very thin shock mount i pinched the the stock metal mount between 2 pieces of thick brass because the stock mounts keept bending and one of the small tack welds broke |
03-07-2008, 10:05 PM | #9 |
Drooped it out, now I need to get the lexan on it: |
03-27-2008, 09:57 PM | #10 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
did you guys buy the kit or just the chassis and go from there....if the kit, what rims come with it....whats the lenght of the shocks you can use on it from the shortest to the longest...............bob .... |
03-30-2008, 04:04 PM | #11 |
nuts5000 what shocks are you running up front..................bob .... |
03-30-2008, 04:23 PM | #12 |
Newbie Join Date: Mar 2008 Location: Sonoma
In those pictures it's the stock Axial shock, with the upgraded shock bodies.
04-02-2008, 10:05 AM | #13 |
things have changed a little bit... losi shocks (full droop --2 3/8 belly clearence) traxxas metal yokes w/ traxxas drive shafts... waiting on MIP shafts rc4wd alum. wheels 45 turn motor w/ 9tooth pinnion alum. body panels |
04-02-2008, 10:05 AM | #14 |
oh yea trak-lockers too... |
04-02-2008, 10:56 AM | #15 |
Hey what type of transmission are you running with the 9 tooth?
04-02-2008, 11:05 AM | #16 |
Quarry Creeper Join Date: Mar 2008 Location: Huntington Beach
those r some real nice rigs.
04-02-2008, 11:35 AM | #17 |
R2D tranny
04-02-2008, 11:39 AM | #18 |
Quarry Creeper Join Date: Mar 2005 Location: hudson (the big city)
finally got to work on my axial based rock rider chassis. i just built an ax10 sw2 so my motivation hasn't been there for the rock rider. i got the axial tranny mounted up and everything else is ready to go. the only thing i have to do now is is get my upper link measurements once the axles are bolted up. i'll be posting pics once it's complete.
