Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: battery question
Old 03-11-2008, 03:19 AM   #1
Default battery question
if i took a normal pack of battery and cut it open and re solder it.....does it fit on the axle in any way......because i try to build a saddle pack and realize it doesn't fit on the axle.....is there anyway to build it so it fits???pic would be nice
ultraman69 is offline   Reply With Quote
Old 03-11-2008, 03:36 AM   #2
A pic of what you tried to do would be helpful, then we could tell you where you screwed it all up. :-P
Philistine is offline   Reply With Quote
Old 03-11-2008, 07:42 AM   #3
Nor-CalRCRC
montereycrawler's Avatar
I am assuming by "normal battery pack" you mean a sub c stick pack.
(If you aren't sure what size, ie; sub c, 2/3 a etc. you can check here and compare your cell dimensions against what is listed)
http://www.cheapbatterypacks.com/main.asp?sid=662924&
If you have sub c cells it is going to be extremely difficult to get a saddle pack configuration to work on your front axle. The people who do use saddle packs on the front axle usually use 2/3 a cells.
Here is a pic of a saddle pack on my son's Ax-10.
montereycrawler is online now   Reply With Quote
Old 03-11-2008, 08:58 AM   #4
Here's how I have mine.
Click the image to open in full size. ^ this is the 1/2 cell offset
^ This is the 1 1/2 cell offset
Hope this helps.
-Tim
Tim_B is offline   Reply With Quote
Old 03-11-2008, 11:43 AM   #5
The sub c will rub.
2/3a will work best. Check out cheapbatterypacks.com.
Flatcrawlr is offline   Reply With Quote
Old 03-11-2008, 01:46 PM   #6
this is a sub c pack mounted over the servo. It wooks ok I like my 2/3 c pack better
skate is offline   Reply With Quote
Old 03-11-2008, 07:40 PM   #7
thats how mine is set up, no rubbing or anything.
RcFanatic92 is offline   Reply With Quote
Old 04-24-2008, 01:54 PM   #8
Hey that looks great! I want to do the same thing but need help with the wiring! any help will be great!!
1807nicholas is offline   Reply With Quote
Old 04-25-2008, 12:22 AM   #9
wiring is very easy. Start with 4 cells laying flat and solder them together. Line them up on top of the servo and fit another cell on one side and figure your angle required for the battery bar. repeat on the other side as well. Once that is done solder your leads that hook to the ESC and Deans or whatever connector you want to use. heres a pic to maybe help a bit. (sorry for the roughness of it I spent like 3 minutes in PS working that up for an example) Also get some good velcro to add to the top of the servo and bottom of the battery. When my digi cam springs back to life I'll snap you a pic of my batteries. Hope this helps some.
DanTaylor is offline   Reply With Quote
