Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Open Diff
Old 03-12-2008, 08:14 AM   #1
Default Open Diff
Hello
I would like to install a open diff in the front axle of my ax 10 projekt.
Is there a option to do this. I searched around but couldnt find anything.
I know that for crawling a open front diff isnt really the way to go. But for my projekt it would be perfect. Its gonna be more a trial und racerunner truck.
Greetings
Swiss is offline   Reply With Quote
Old 03-12-2008, 04:46 PM   #2
Axial's Avatar
We have gears available from the RTR to install into your axles for an open diff.
The part numbers are below:
AX30390 Differential gear set
You can download the RTR instructions and take a look at page 9 for installation directions.
Thanks,
Axial
Axial is offline   Reply With Quote
Old 03-12-2008, 04:53 PM   #3
Can the diff be turned into a slipper type diff? or will you have to change the lock up by changing the grease?
Oze30 is offline   Reply With Quote
Old 03-13-2008, 11:18 AM   #4
Axial's Avatar
It will need to be tuned with grease.
Thanks,
Axial
