Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: ax-10 driveshaft angle (side to side)
Old 03-13-2008, 03:42 PM   #1
Default ax-10 driveshaft angle (side to side)
anyway to straighten out the side to side angle of the driveshaft?
ykcor is offline   Reply With Quote
Old 03-13-2008, 03:49 PM   #2
Axial Team Driver
Brandon's Avatar
Any reason why? Just move the tranny over
Brandon is offline   Reply With Quote
Old 03-13-2008, 04:08 PM   #3
The side to side is not the issue most of the time - its the up/down relationship - this is cured by lowering the chassis - you'll find many ways to fix that on this forum - as stated above - just move the tranny over as far as you can & drill some new holes in the skid
Yawzer is offline   Reply With Quote
Old 03-13-2008, 04:21 PM   #4
I know of a company that is working on developing axles with offset differentials, just like the rock buggies use in 1:1 comp. This would eliminate what you are speaking of here, as well as be the ultimate in ground clearance.
DirkDigler is offline   Reply With Quote
Old 03-13-2008, 04:37 PM   #5
that's what i'm talking about. off set differentials!
inline driveshaft less wear and better power.
move tranny over motor will hang out unless i angle it up
Old 03-13-2008, 08:37 PM   #6
I couls see moving the rear pinion over, even the front as a potential problem. I have my pinion moved up for better ground clearance in the rear and even with the 4 link, I borrow the area between the links for room went flexed out. Same with the frontespecially with the stock 3 link setup.
nathaninwa is offline   Reply With Quote
Old 03-13-2008, 08:59 PM   #7
Better power? Forgive me for being rude but its a dang toy. Movin the shaft wont get you any more power. If you want power then get a real 1:1 rig.
jpcherokeekid is offline   Reply With Quote
Old 03-13-2008, 09:52 PM   #8
Its probably not a good idea to come on this site and start bashing rc crawling. (if you want more power try a 3cell lipo)
mtnyote is offline   Reply With Quote
