Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: wheel extensions
Old 03-14-2008, 01:50 PM   #1
Default wheel extensions
I've got the proline 8 shooters and they sit up against the knuckle right now. :-( Any idea how big of an adapter i need to run? I see crawford has one that is .75" are there others or will this be enough?
kurt is offline   Reply With Quote
Old 03-14-2008, 02:16 PM   #2
had the same problem dont think u need to go out that far.....i found some thicked hexs in my stash..think they are from traxxas....stampede they came in a 4pack 2thick/2thin thick one added 1/8 that was enough
integy just came out with a +15mm/.6"set that includes shaft
hpi has also got a set+25mm/.9" hex hubs that use barrel bolts
gadge is offline   Reply With Quote
Old 03-14-2008, 02:33 PM   #3
The Infidel
Erin's Avatar
I tried the adjustable set, 25mm-35mm, but they are way to wide. like was said, you only need to add about an .125", or shave the knuckle and beadlock down.
Erin is online now   Reply With Quote
Old 03-14-2008, 02:40 PM   #4
looks like i am knuckle shaving. :( those poor rcp's
Old 03-15-2008, 04:12 AM   #5
How much material do you end up having to shave? I'm eyeballing the proline wheels, but really want to run RCP's knuckles. Pics anyone? Thoughts on long term durability if they're shaved?
Mortimer Snerd is offline   Reply With Quote
Old 03-15-2008, 07:54 AM   #6
not much. it doesn't affect their strength at all. i was worried at first but the wheel doesn't completely cover the hex. that extra 1/16" is what i was worried about. I just held the wheel on to see right where it was hitting, pulled it off and then shaved it down with the dremel. .8mm - 1.0mm should be plenty
