Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: CKRC Rockstar Build
Old 03-14-2008, 11:44 PM   #1
Default CKRC Rockstar Build
Got a Rockstar from CKRC the other day. It came with bare aluminum plates, delrin skid, and all the screws needed. I filed all the edges and painted it black. The skid is drilled for both the Axial and R2 tranny.
Skeeno is offline   Reply With Quote
Old 03-14-2008, 11:46 PM   #2
The plates and skid are different on each side, so here is a pic to show you how it works for the R2D. It may be different for the Axial tranny. Notice the direction of the skid and side plates; top is front, bottom is rear.
Old 03-14-2008, 11:53 PM   #3
Everything bolted up easy. This chassis is really narrow. Space is tight. Added one small washer on the motor side to gain 1mm clearance for my 16t pinion. You can see them in the bottom pic. I don't think this would be necessary if I used a 14t pinion.
Old 03-14-2008, 11:58 PM   #4
Cut the upper brace down to fit. I think it's close to 50mm, maybe 49mm. I just cut off the flare on the end. I used to stock battery plate mounts to space the body mounts back out and I put the plate on to add some strength. I have heard some worry that the chassis seemed thin and would fold on a good fall. CKRC beefed up the chassis a bit, but I don't think it was really needed. Jake took an 8ft fall on to his front wheels at the Utah comp with no issues. The plate is just precautionary.
Old 03-15-2008, 12:04 AM   #5
Starting a new build the night before a comp...
Hope everything comes together for you
Spucknit is offline   Reply With Quote
Old 03-15-2008, 12:05 AM   #6
Pretty much finished. It took me about an hour to complete.
Old 03-15-2008, 12:06 AM   #7
Looking good
Trimmy is offline   Reply With Quote
Old 03-15-2008, 12:08 AM   #8
Ready to Rock!
Old 03-15-2008, 12:21 AM   #9
Had some requests for width. The new chassis is 3/4" narrower. Stock is 3 1/8", the Rockstar is 2 3/8".
Old 03-15-2008, 12:25 AM   #10
hitman46mod's Avatar
DA DA DA DA DA DA DA da bat crawler
hitman46mod is offline   Reply With Quote
Old 03-15-2008, 02:10 AM   #11
Default rockstar
looking good Skeeno.I just got done with mine. I think there is like 5 of us
that are going to the comp with are new crawlers aka(ROCKSTARS).
JUGGHEAD is offline   Reply With Quote
Old 04-19-2008, 09:00 AM   #12
Has anyone attempted to mount the VF dig in the chassis?
BMAC is offline   Reply With Quote
Old 04-20-2008, 11:05 AM   #13
Call CKRC and ask them. 775-378-5503
Old 04-20-2008, 11:11 AM   #14
Looks like your driveshafts are gonna be in for it.
BigRocks is offline   Reply With Quote
Old 04-20-2008, 09:38 PM   #15
OMG I was dying when I read that... Holy Rock Claws Batman, that rock is slippery!
The build looks good. How'd it do at the comp?
rdtshaw is offline   Reply With Quote
Old 04-20-2008, 10:16 PM   #16
What mods are done to your driveshafts?
RC Shocker is offline   Reply With Quote
Old 04-20-2008, 11:07 PM   #17
The chassis performed well, but I had lots of glitches. I finished middle of the pack. I have since switched to a 2.4 radio. No more glitches. The other Rockstars took all three podium spots.
Drive shafts are stock axials. Rear one has been cut down a bit for the R2D and I added the Axial rings to strengthen them.
Old 04-21-2008, 08:58 AM   #18
I was told the Vf dig is too wide for the chassis. I would have to widen the the chassis out about a quarter inch.
Old 04-21-2008, 02:09 PM   #19
KING BLING's Avatar
the vf will fit, but you will have to redrill your own mounting pattern. It just needs to be clocked a 1/8" over.
KING BLING is offline   Reply With Quote
Old 04-21-2008, 10:47 PM   #20
King do you have a good pic of your dig set up? Im starting mine and Im kinda lost as usual. Thanks!
Name:  pics 024 (600 x 450).jpg
Name:  pics 025 (600 x 450).jpg
Name:  pics 026 (600 x 450).jpg
crawlbe4youwalk is offline   Reply With Quote
