Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: lower link rod ends??
Old 03-17-2008, 11:39 AM   #1
Default lower link rod ends??
well yesterday my buddy got my truck pretty bound up and broke the lower link rod end, where it goes to the diff. its that little off set rod end. well anyways does any one run just straights or do i need to get the off set ones.
maro69camaro is offline   Reply With Quote
Old 03-17-2008, 11:53 AM   #2
2006 2.2 National Champ
BENDER's Avatar
You can switch over to the straight rod ends without any issues.
BENDER is offline   Reply With Quote
Old 03-17-2008, 11:56 AM   #3
Originally Posted by BENDER View Post
You can switch over the the straight rod ends without any issues.
thanks bender, will work on that tonight...
Old 03-18-2008, 12:29 AM   #4
After breaking a couple of my Axial offset lower end links I'm using the Traxxas # 1492 bulk pack of Stampede rod ends and they work great...much stronger than the Axial plastic ends.
Old 03-18-2008, 01:27 AM   #5
calcat430d's Avatar
hot racing has lower links . bent 30 degrees with metal rod ends . I just ordered some from rpp. they were under 17 bucks for a pair. no more stripping or breaking ends for me.
calcat430d is offline   Reply With Quote
