03-25-2008, 10:35 PM | #1 |
Newbie Join Date: Mar 2008 Location: cincinnati
| axial scale chassis (TCS X-Trail Chassis)
TCS X-Trail Chassis: Does anyone know if this chassis will dramatically decrease the crawling performance? http://www.tcscrawlers.com/Pre-Order...n-p-16556.html |
03-26-2008, 03:16 AM | #2 |
Quarry Creeper Join Date: Sep 2005 Location: Sandy, UT
To be honest with you, if it was set up correctly, I think it could crawl every bit as well as the stock chassis.
03-26-2008, 05:02 AM | #3 |
Pebble Pounder Join Date: Dec 2006 Location: uk
i run mine with 2.2 on and crawls perfect |
03-26-2008, 02:07 PM | #4 |
thanks a lot. so you have this chassis then? I want my crawler to perform but i am going for the scaled look as well so i just want it to be as scaled as possible but still perform.
03-26-2008, 02:12 PM | #5 |
| With the right setup, you'll get comp ready performance out of that chassis. People have been running K2 chassis in comp rigs ever since they came out, and they work great. This chassis would be pretty much the same.
03-26-2008, 02:37 PM | #6 |
03-26-2008, 04:22 PM | #7 |
alright thanks. it just seemed like it would greatly reduce the travel or twist the crawler would have.
03-26-2008, 04:48 PM | #8 |
i found with the stock axial shocks (droop set up)it had more flex than you need and i ended up limiting the shock travel
