03-26-2008, 03:02 PM | #1 |
Pebble Pounder Join Date: Jan 2008 Location: Oak Harbor
| Upgrade Questions
I have a stock scorpion and I have some questions before I upgrade. 1. I have 2 pairs of bent lower links but cant use them until I move the lower links inside the chassis. I was thinking of going with the TCS derlin skid, but I am hearing good things about homemade double triangulation skids. ----- Also, if I make my own double tri. skid, should I make the chassis skinnier, and how much? I dont want to make it so skinny that I would have to cut the chassis to make motor clearance, UNLESS IT WILL MAKE A HUGE DIFFERENCE? 2. I have decided to get a 2/3 split 6 cell pack for the front axle. Should I do IB 1400 cells or Elite 1500 cells? I am more concerned with qualitiy over a little more runtime. I would do lipo but I dont have the mula:-( Sorry for the LONG post, but I do appreciate your time |
03-26-2008, 05:37 PM | #2 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
1)double triangulation is the best mod that i have done to my rig. better than rock claws, better than the r2d tranny, better than the 5955 tg servo, ect. Also, it was very inexpensive 2)i have already told you on several of your threads that those batteries are a waste of money, so....... side note: dude, can you please pick a new name because person 123 is f**king stupid. you've spent enough time on here to come up with a name |
03-26-2008, 06:09 PM | #3 |
does anyone know of a person that sells skids set up for double triangulation? If not, what is the most common design, material, thickness, etc. Yeah I know, use the search button; I have ok.
03-26-2008, 06:16 PM | #4 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
1. Really depends on how much fabrication you want to do. Double triangulation is good stuff, but is tougher to set up (obviously). I don't see any reason you can't run the bent links in the stock configuration. You won't be able to narrow it much without cutting the chassis. Inboarding the links is pretty easy. 2. Both cells will serve you well, despite what mtnyote has to say. The elites carry their voltage a little longer, and are probably the better choice between the two. Both work well, and you'll be happy with either. That said, lipo rules. Last edited by Mortimer Snerd; 03-27-2008 at 11:36 PM. |
03-26-2008, 06:24 PM | #5 |
Rock Stacker Join Date: Mar 2008 Location: Arvada
03-26-2008, 07:36 PM | #6 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
yup x2 I have a 2 dollar cuttin board in mine as a skid... I haven't narrowed mine just the double tri and it was like mtnyote said the best mod done so far to mine... this weekend I will be narrowing mine and see how it does from there... I'm just doing little things till I get all my parts in to build a whole new rig... The ax-10 can only go so far. But it's great for suckin in the new guys...... " oh hey man try this"... (well I drive the new one he drives my old one) and hooked! How do you think I got hooked... this shit's like crack once you get a little you can't get enough! |
03-26-2008, 08:00 PM | #7 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
03-26-2008, 09:53 PM | #8 | |
| Quote: Thanks everyone | |
03-26-2008, 10:25 PM | #9 |
| No the screw go though the chassis plate, though the skid and you mount the lower link to it. I personely have been running this mod for about 3 months now and it works awesome. The skid plate is made out of a 3/8" plastic cutting board, that you can buy at Walmart.
03-26-2008, 10:32 PM | #10 |
could you please find me a larger piture, and a template because I really like that design! Thanks
03-27-2008, 07:06 AM | #11 |
Quarry Creeper Join Date: Jan 2008 Location: marysville
Figure it out yourself by studying pictures, like many others have in the past. Or you could send your truck to someone so they can make and install the skid for you. |
03-27-2008, 02:51 PM | #12 |
03-27-2008, 05:45 PM | #13 |
03-27-2008, 07:03 PM | #14 | |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
Yotachump's Ax10 | |
