04-02-2008, 10:10 AM | #1 |
Quarry Creeper Join Date: Apr 2008 Location: Carson City
| CKRC straight axle kit?
I was woundering on how to put this straight axle kit together. If anyone has any pics on putting one together, or tips. thanks
04-02-2008, 11:15 AM | #2 |
I would assume they go together just like any other adapters. Pull the axle C's of with the 2 screws (front and back of the axle). Pull the old axle out, put in the new straight axle. Slip on the new axles adapter and screw in back on the axle. Bolt on the stock axle carrier. Walla.
04-02-2008, 11:27 AM | #3 |
The axle keeps sliding away from the lockers, I was woundering about the slop in between the c-clips and the bearings , should I run 3 bearings instead of 2. thanks
04-02-2008, 11:32 AM | #4 |
I joined the Band! Join Date: Dec 2007 Location: cotati
one bearing goes at the end of the axle housing and one goes inside the axle adpt. |
04-02-2008, 11:35 AM | #5 |
Quarry Creeper Join Date: May 2007 Location: Brenham, Tx
i ran 3 beaings. one in the axle housing and 2 in the adapter. i can pull mine apart and get pics if you want |
04-02-2008, 11:36 AM | #6 |
Rock Crawler Join Date: Feb 2008 Location: Golden Corral getting Fat
I had same problems with mine it is tricky
04-02-2008, 12:33 PM | #7 |
Yeah I would love some pics. Do you know what size bearings those are. thanks I need to order 2 more.
04-02-2008, 01:23 PM | #8 |
Quarry Creeper Join Date: Dec 2006 Location: Corbin KY
they are the small bearings that go on the axle tubes. The one at the end of the axles and the small one out of the knuckle.
04-02-2008, 01:35 PM | #9 |
04-02-2008, 02:55 PM | #10 |
the pictures are way too dark so i used my mad paint skillz instead. hopefully its self-explanatory |
04-02-2008, 07:03 PM | #11 |
Quarry Creeper Join Date: Feb 2008 Location: Lagrange
i got it and the axles i got seem to be a bit to long and wouldnt go together any whicha way
