04-03-2008, 07:29 AM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: York, PA
| one piece links?
Does anyone make one piece links for the ax-10? I am really tired of stripping the ball ends out
04-03-2008, 07:58 AM | #2 |
Pebble Pounder Join Date: Nov 2005 Location: NKY
Yep... Integy http://www.integy.com/cgi-bin/webc.c...=5526&p_catid= If you scroll down on this page: http://www.integy.com/cgi-bin/webc.c...ml?p_catid=107 You will see the different lengths they have. |
04-03-2008, 09:29 AM | #3 |
Rock Crawler Join Date: Sep 2007 Location: Petaluma
Have you tried useing loc-tite.it works for me..
04-03-2008, 10:01 AM | #4 |
Rock Crawler Join Date: Sep 2007 Location: Colorado Springs
I use 3/8 delrin, 8/32 althread and Jato rod ends. I tap the Jato ends to 8/32. Been using the same links for months!! No issues at all. For about $15-20, you have links for a long time!! Just a thought.
04-03-2008, 12:27 PM | #5 |
You definitely have some other type of issue. Are you using cheap rod ends or the wrong thread size? I also run Jato ends tapped to 8-32 with 5/16" Delrin rod. Lots of hard falls and still no breakage. |
04-03-2008, 02:29 PM | #6 |
Rock Stacker Join Date: Mar 2008 Location: Velva
in that pic it looks like the ends on the integy ones are not in line with eachother and arent adjustable..hows that work
04-03-2008, 08:53 PM | #7 |
Quarry Creeper Join Date: May 2007 Location: melbourne, australia
screw the grub screw into the rod end further, the only time i have ever stripped one of the rod ends was when i only had about 3mm of thread going into the plastic
04-04-2008, 01:26 AM | #8 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
^ What they said. Axial makes some badass rod ends. I find it hard to believe they are just mysteriously stripping
04-04-2008, 05:17 AM | #9 |
Maybe I cross threaded a couple when i first built the rig. I just bought some traxxas ones from the lhs. I will give them a try. Thanks guys
04-04-2008, 12:00 PM | #10 |
Newbie Join Date: Mar 2008 Location: Phila
The traxxis end links are really strong. I haven't had any problems with my stock axial ends, besides threading the set screw in too far... |
04-04-2008, 06:10 PM | #11 |
Quarry Creeper Join Date: May 2007 Location: Rancho Cambodia
1/4" derlin sleeved over 4/40 all-thread, then jb weld the rod ends on industuctable ill bend and break bolts befor a link
