04-17-2008, 06:30 PM | #1 |
Newbie Join Date: Apr 2008 Location: Diamond
| Battery set-up Help
I just built my first AX-10. I need some help deciding what battery and location to run. I like the clean look of lipo's on the factory tray but am looking at mounting 6 cells to front axle or 4 cell. What ever you think is the best and if it looks clean I want to see it. What size cells are used to mount 3+3 on each side of servo. I am open to all and any ideas or pics. Thanks and nice to meet you all, Mark |
04-17-2008, 06:44 PM | #2 |
Rock Crawler Join Date: May 2007 Location: lacey
I run a 6 and 7 cell split pack on my front axle. TCS Crawlers, $20 bucks for the 6 cell, ~$23 for the 7. looks good and way cheaper than lipo, but you cannot beat the punch a lipo delivers.
04-17-2008, 08:03 PM | #3 |
| Size
What size cells are in your split packs? Are you using receiver packs or are you building them? I have found that the standard 7.2V stick pack cells are too big for the axle but the smaller cells like thoughs found in 7.2V Airplain packs or hump packs for servo power on nitro's fit better. I have been in RC forever but new to crawling. feel free to send pics. I have the airplane packs on the axles for know 'till I find a better way. I may go lypo but I like the extra weight of the NIMH cells. and yes they are cheaper Thanks, Mark |
04-17-2008, 08:12 PM | #4 |
Rock Stacker Join Date: Feb 2008 Location: Where ever the Army puts me.
The cells that are in the split packs are 2/3A cells. Hope this helps Mark.
04-17-2008, 08:23 PM | #5 |
RCC Addict Join Date: Nov 2007 Location: Nine Mile Falls, WA
Here's our List of crawler packs both 2/3rd cell saddle packs and Li-po's. I've been working directly with Axial to develope as many different packs as we can that will work with the Axial Scorpion and other crawlers. If you have questions feel free to ask. http://www.maxamps.com/products.php?cat=82 Jason |
04-17-2008, 08:39 PM | #6 |
Rock Stacker Join Date: Dec 2006 Location: in the workshop
JAM - jason, I've been out of r/c for a couple of years now and am getting back into it with a crawler build, my question is: is there any standardization to the size of lipo cells, i'm so used to sub-c's in nicads and nimh and Its making it really hard for me to figure out which lipo to go with, ideally I'm thinking of a front servo mount plate that extends back and up at a slight angle and so farr it looks like your 1100mah 3s pack 66mm x 34mm x 19mm seems to be my best option, but if i was to ever buy from someone else it seems like there packs are all different sizes, also, that pack is priced at $34.99 on your site, why are lipo's so much cheaper than say a 4600 nimh matched pack? Thanks, |
04-17-2008, 09:04 PM | #7 |
| Thanks
Thanks Jason those pacs look great. I will order some next chance I get. Thnaks Mark |
04-18-2008, 07:42 AM | #8 | |
Jason | |
04-19-2008, 12:54 PM | #9 | |
Quarry Creeper Join Date: Apr 2008 Location: Fondy, WI
04-19-2008, 08:31 PM | #10 | |
Thanks, Mike | |
04-19-2008, 09:09 PM | #11 | |
I joined the Band! Join Date: Oct 2006 Location: RcFanatics.net
Right now I run a stick pack mounted on my front axle over the servo until I can find a decent set of saddle packs. Dont get me wrong, I LOVE TCS. Fast shipping great prices, great communications, just Ive had horrible luck with them packs. | |
04-19-2008, 09:40 PM | #12 |
| 9 Amps !!!!
(Ive ordered 2 different sets of the saddle packs from TCS and both sets would charge fine (at. 9 amps) then will hold a charge for about 3-4 mintues, then die. I thought maybe my 1st set was just bad, but my other pack did it too.) I think you should only charge at about 1.5 amps not 9. I am using some old 6 cell airplain pacs and man they last for 50 minutes or so if I charge 'em at 1.5 amps. I think you killed 'em at 9 amps their knock. |
04-19-2008, 11:33 PM | #13 |
Rock Stacker Join Date: Apr 2008 Location: Houston
| x2, the most you should try on a cheap pack would be 4 Amps. FAster charge = more power, slower charge = longer run times. 2.5 is what I use with great results
04-19-2008, 11:38 PM | #14 | |
04-20-2008, 11:32 AM | #15 | |
Newbie Join Date: Apr 2008 Location: Camp Hill
Could I bother ya to see what your doing? I was just getting ready to order...well PM maxamps about the proper battery packs, but then seen your post about center, low but still forward. I would be curious to see your drawing if you dont mind sharing! Teegandangie@yahoo.com Last edited by Venomos; 04-20-2008 at 11:34 AM. | |
04-20-2008, 12:59 PM | #16 | ||
04-21-2008, 12:44 AM | #17 |
