04-19-2008, 01:35 AM | #1 |
Quarry Creeper Join Date: Apr 2008 Location: Fondy, WI
| battery placement and options
hi guys. i am going with lipo on my axial and want to use the longest lasting battery that will be compatible w/ my edge chassis. does anyone have advice or pics of which lipo battery would give me the longest run time with still being compatible, and ideas on the best way to mount it on my rig? thanks!
04-19-2008, 01:58 AM | #2 |
Like a boss... Join Date: Feb 2008 Location: NorCal
Axial makes an offset servo mount that will allow you to move your servo off to one side and place a battery pack next to it. I can fit a Thunder Power 1320 Mah 2 or 3 cell Lipo there with no issues. Based on those dimensions, the 2000 MAh from them should fit as well. Common Sense RC makes a 2000 Mah that should fit too. Also what many guys will do is make a tray out of lexan or styrene and place them on the upper links. You can use and get a little bigger battery in those situations too. I suggest you poke around on some different build threads with pics and you'll find an idea that suites you. -Mike |
04-19-2008, 08:41 AM | #3 |
RCC Addict Join Date: Nov 2007 Location: Nine Mile Falls, WA
If you go to this link: http://www.maxamps.com/categories.php?cat=13 then Click on the Axial logo to take you to the complete list of packs that I have work directly with Axial on to get as many different options available to fit all the different battery monuting options that are available. We ahve the only Li-Po saddle pack that will fit on the TCS front plates. We have several packs that will fit on the Axial Optional servo/battery tray. And another solution is a tray monuted to the upper links on the front. Depending on what motor system and esc you have will be a deciding factor also can you run 2S packs only or can you step up to a 3S pack? For runtime a 1720 2S will take you 30 to 40 minutes an 1100 will take yo 25 to 30 minutes and 860 saddle will take you 25 minutes and a 1550 will put you around an hour and the 2000 will go way over that. If you have a 2S set up our 3300 will well you know a lot of run time. All the packs have the measuremants list under "more Info" so you can see for sure what will fit before you order. If you have any questions just ask. Jason |
04-19-2008, 05:28 PM | #4 |
Rock Stacker Join Date: Jan 2008 Location: Lexington
Jason Of the two saddle packs you carry. I noticed one is 7.2 and the other is 11.1 volts. What kind of runtime can I expect out of these packs?Which do you recommend? Thanks |
04-19-2008, 11:50 PM | #5 | |
the higher the mah number, the longer the run time. Last edited by jedsled; 04-19-2008 at 11:53 PM. | |
04-19-2008, 11:52 PM | #6 | |
04-20-2008, 07:19 AM | #7 |
| So what would be better more or less punch? And will the 11.1 v be too much volatage for a spectrum receiver?
04-20-2008, 09:16 AM | #8 |
I can 25 to 30 minutes with the 860 saddle pack. As Jon Homles says volt up gear down. And the battery pack voltage won't hurt the receiver. You just need to see if your esc is li-po ready and how many cells it can handle The Novaks will do 2S while the Mamba's and Sidewinfder can do 3S max. Jason |
04-20-2008, 09:57 AM | #9 | |
04-20-2008, 10:18 AM | #10 |
Quarry Creeper Join Date: Jan 2008 Location: marysville
04-22-2008, 07:59 PM | #11 |
Rock Stacker Join Date: Nov 2007 Location: Sacramento
I am running a 6 cell 4500mH pack over the front axle. (3 cells over the servo and 1 on each side of it) Looks kind of like a bracket. That pack runs for a long time. I am not sure of the actual run time, but I can play around for about 4 hours before I need a charging. By them I am ready to go home.
04-22-2008, 11:25 PM | #12 | |
04-23-2008, 12:56 PM | #13 |
Newbie Join Date: Aug 2007 Location: West Tennessee
04-24-2008, 03:18 AM | #14 |
04-24-2008, 06:21 AM | #15 |
Quarry Creeper Join Date: Sep 2007 Location: Middle of the USA
Go with the three cell, you will crawl forever. Also they now have a split pack lipo fo rbuggies that would work great!
04-24-2008, 07:31 AM | #16 |
04-25-2008, 05:01 PM | #17 |
04-25-2008, 07:06 PM | #18 |
We already have a compatible saddle pack for the front axle of the AX-10 it's an 860 mAH saddle in both 7.4 and 11.1 volts. It will get you around 25 to 30 minutes of runtime with a 55T lathe motor. You need the TCS front battery plates to use them. These are the biggest Li-Po's that will fit between the front center mounted servo tray. Jason |
04-25-2008, 10:02 PM | #19 |
Quarry Creeper Join Date: Mar 2008 Location: Raleigh, NC
would anyone know if a novak crawler esc can be ran with a 9.6V with a 8 cell pack SAFELY ??? I don't want to hurt the esc, 10v seems too high to me.
07-10-2008, 07:12 PM | #20 |
Newbie Join Date: Jul 2008 Location: ellijay
yea 8 cells is to much i run a 7 cell in mine got the tcs mounting plates and mounted them on the front axal |
