04-24-2008, 02:22 AM | #1 |
Rock Stacker Join Date: Feb 2008 Location: Vancouver, Canada
| Loud Clicking Noise
I just put together my AX-10. It's stock. When I drive it, it make loud clicking sound. It clicks porportional to speed, so it's got to be rotating parts. I took the motor away and the roll is all quiet. And the motor is fine. So I am stumped. I don't know what I can do. Appearly the pinion gear and the spur are making the noise. But how can I mount a motor differently?? No way. I am getting annoyed? ANyone have this problem before? |
04-24-2008, 02:29 AM | #2 |
Rock Stacker Join Date: Jan 2008 Location: Lexington
MIne did also when I first put it together and it was from the motor be cocked side ways a little. Reinstalled the motor and everything was fine. MAke sure your mesh is right.
04-24-2008, 02:42 AM | #3 | |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
If its the Novak 55.....the click will go away. | |
04-24-2008, 04:35 AM | #4 |
Quarry Creeper Join Date: Nov 2007 Location: NH
Mine did that also, I ended up moving the pinion a little further away from the motor
04-24-2008, 06:20 AM | #5 |
Quarry Creeper Join Date: Sep 2007 Location: Middle of the USA
Yes mine was a pinion problem to!
04-24-2008, 07:16 AM | #6 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
It's usualy the pinion gear. On a brushed motor, you have to push it all the way in on tha motor shaft. |
04-24-2008, 07:59 AM | #7 |
Newbie Join Date: Mar 2008 Location: Oberlin
I Had the same problem, if you notice the spur gear is turning on top of the set screw of the pinion you either need to turn it around so the screw is close to the motor or side in or out so the set screw on the pinion clears the spur gear. Thats what i had came up with on the clicking noise. Also when you adjust the clearance between the pinion and the spur make sure not to adjust so tight, just a slight little movement is need between the two. Eric |
04-25-2008, 10:45 AM | #8 | |
