05-07-2008, 09:42 PM | #1 |
Pebble Pounder Join Date: Apr 2008 Location: brookland
| Shock Upgrade
im looking to upgrade the stock shocks to an aluminum version and would like to know what yall reccomend, also what length they should be. thanks in advance
05-08-2008, 10:30 AM | #2 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
I run 4" Losis. Great shock, much nicer than stock.
05-08-2008, 10:40 AM | #3 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
yes, go with the losi crawler shock set. RCP is out of stock right now, but im sure many vendors carry them. http://www.rcpcrawlers.com/product.p...&cat=14&page=1 |
05-08-2008, 11:17 AM | #4 |
Pebble Pounder Join Date: Apr 2008 Location: Long Beach Ca.
Give Jakes Performance Hobbies A call I just received my shocks from Jake he should have them in Stock. At a Great price also. http://www.jphracing.com/ |
05-08-2008, 11:40 AM | #5 |
Rock Stacker Join Date: Jan 2007 Location: Lincoln
What weight shock oil would you use in those?
05-08-2008, 11:43 AM | #6 |
Newbie Join Date: Nov 2007 Location: Seattle, WA
Another vote for the Losi 4" Crawler shock set, part # LOSA5082. The only downside is Losi is backordered so you need to find a retailer with a set in stock. Before the losi's I tried Traxxas Big Bore Alum shocks and while they were a upgrade over the stock plastic shocks (what isn't), they still leaked badly. The Losi's have not leaked a drop since installing them and are FAR smoother. Note, the Losi shocks are shorter then the stock shocks and you will need to make some changes to accomodate. |
05-08-2008, 01:47 PM | #7 |
Rock Stacker Join Date: Jul 2005 Location: Strongsville
anyone try the aluminum threaded emaxx shocks? I happen to have an extra set and was going to swap out - wondered if anyone has used them and how they performed.
05-08-2008, 01:50 PM | #8 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
I like the Traxxas Big Bores! there as smooth as butter. |
05-08-2008, 02:21 PM | #9 |
05-08-2008, 05:30 PM | #10 |
What mods are needed to get the losi shocks on? They dont just bolt up?
05-08-2008, 07:14 PM | #11 |
i was thinking bout using associated 1.32 threaded body shocks from like a t4 ....anybody use those? n yea what mods u gotta make to use the losi shocks?
05-08-2008, 07:55 PM | #12 |
Quarry Creeper Join Date: Mar 2008 Location: Hilo
Im running JpCustomRcs threaded aluminum shocks. 30wt with the blue springs. They are smooth and dont leak. I got the 110mm ones since the 100mm were out of stock.
05-08-2008, 11:03 PM | #13 |
| Sort of. You have to use fuel tubing for the upper shock mounts. Its a little cheesy, but works really well. Also, they're a little shorter than stock, so you have to use a longer ball end than stock. Limiters also helps on stock chassis.
