Thread: best way to increase wheel speed?
Old 05-10-2008, 07:28 AM   #1
Default best way to increase wheel speed?
have a stock gearing setup right now in my ax10 2.2 setup and need alittle more wheels speed to help clear some gaps. any tips on gear selection or specific vendors?
2004neonsrt4 is offline   Reply With Quote
Old 05-10-2008, 08:15 AM   #2
What the stock gearing, i forget? I need a new one to i'm running a 75T motor and its not cutting it with speed...
madmax22 is offline   Reply With Quote
Old 05-10-2008, 08:16 AM   #3
666
MODERHATER™
666's Avatar
Gear down, volt up man!!
666 is offline   Reply With Quote
Old 05-10-2008, 08:30 AM   #4
throw on another cell or 2 in your battery pack, check the specs on the esc to see what it can handle first.
rcracer is offline   Reply With Quote
Old 05-10-2008, 08:41 AM   #5
binaryterror's Avatar
75T is very slow. Try the more normal 55T or even a 45T.
binaryterror is offline   Reply With Quote
Old 05-10-2008, 08:57 AM   #6
have a 55t now with lipos
Old 05-10-2008, 09:08 AM   #7
try a cobalt puller if that's in your budget.
Crawlerguy851 is offline   Reply With Quote
Old 05-10-2008, 11:19 AM   #8
Looks like three of your main options have been said:
(1) Change your gearing. Either drop some teeth on your spur gear or add more teeth to you pinion. Just remember that dropping three teeth on your spur is about the same as adding one to your pinion.
(2) Volt up. Adding more voltage/batteries will increase the amount power delivered to you motor. But like what was said, make sure you ESC can handle more cells.
(3) Get a different motor. The lower the number of turns in a motor, the faster that motor will spin. Increasing wheel speed.
Cake Eater is offline   Reply With Quote
Old 05-10-2008, 01:13 PM   #9
Well said!
Mortimer Snerd is offline   Reply With Quote
Old 05-10-2008, 02:28 PM   #10
any pinion suggestions
Old 05-10-2008, 02:53 PM   #11
Stock pinion is a 14T. Depending on your motor you might go as high as 19T. But I'd suggest a 16T to try out and see how you like it.
Then consider more voltage, or a different battery.
I am running a 19T with a 3S lipo and a 35T motor ... it's too fast but entertaining in the sand.
Desolas is offline   Reply With Quote
