05-10-2008, 07:28 AM | #1 |
Newbie Join Date: Mar 2008 Location: lancaster
| best way to increase wheel speed?
have a stock gearing setup right now in my ax10 2.2 setup and need alittle more wheels speed to help clear some gaps. any tips on gear selection or specific vendors?
05-10-2008, 08:15 AM | #2 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
What the stock gearing, i forget? I need a new one to i'm running a 75T motor and its not cutting it with speed...
05-10-2008, 08:16 AM | #3 |
Gear down, volt up man!!
05-10-2008, 08:30 AM | #4 |
Rock Crawler Join Date: Feb 2004 Location: Michigan
throw on another cell or 2 in your battery pack, check the specs on the esc to see what it can handle first.
05-10-2008, 08:41 AM | #5 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
75T is very slow. Try the more normal 55T or even a 45T.
05-10-2008, 08:57 AM | #6 |
have a 55t now with lipos
05-10-2008, 09:08 AM | #7 |
Rock Crawler Join Date: Oct 2005 Location: Clarkston, MI
try a cobalt puller if that's in your budget.
05-10-2008, 11:19 AM | #8 |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
| Looks like three of your main options have been said: (1) Change your gearing. Either drop some teeth on your spur gear or add more teeth to you pinion. Just remember that dropping three teeth on your spur is about the same as adding one to your pinion. (2) Volt up. Adding more voltage/batteries will increase the amount power delivered to you motor. But like what was said, make sure you ESC can handle more cells. (3) Get a different motor. The lower the number of turns in a motor, the faster that motor will spin. Increasing wheel speed. |
05-10-2008, 01:13 PM | #9 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
Well said!
05-10-2008, 02:28 PM | #10 |
any pinion suggestions
05-10-2008, 02:53 PM | #11 |
Quarry Creeper Join Date: May 2007 Location: Seattle
Stock pinion is a 14T. Depending on your motor you might go as high as 19T. But I'd suggest a 16T to try out and see how you like it. Then consider more voltage, or a different battery. I am running a 19T with a 3S lipo and a 35T motor ... it's too fast but entertaining in the sand. |
