05-25-2008, 10:10 PM | #1 |
Quarry Creeper Join Date: Aug 2007 Location: Winnemucca
| wobbly front wheels?
I'm running the axle c's & knuckles from ckrc, which are the same as hot racing I think? Anyway it seems like the bearings dont fit totally tight, either in the knuckle or on the stub shaft. And just a small amount of play there is quite noticable at the tire. Anyone else have this problem & what did ya do?
05-25-2008, 10:38 PM | #2 |
RCC Addict Join Date: Jan 2008 Location: Wetlands
How noticable is the wobble? Mines wobbles up and down about 3/8th inch. |
05-25-2008, 10:47 PM | #3 |
Quarry Creeper Join Date: Aug 2007 Location: United States
I am running the RCP knuckles and C's, there is also some wobble in them. I just thought it was normal. I tried to use some shims between where the C and knuckle contact. I think it helped a little. Most of the play seems to be in the bearings and stub axle.
05-25-2008, 10:51 PM | #4 |
What wheels are you guys running? With my wore out stock bead locks,there is a little wobble. I'm running RCP knuckles and adjustable C's. I can run my sons Delrin beadlocks and the wobble goes away. |
05-25-2008, 11:04 PM | #5 |
I joined the Band! Join Date: Dec 2007 Location: cotati
yes the bearings dont have a snug fit... they drop right in without any pressure.. they could be just a snug tighter... and if you crawl like i do you will really get some wobble in about 3 months. |
05-26-2008, 12:37 PM | #6 |
I am running some Mayhem wheels and they fit very tight. The slop is in the bearings. As nuts5000 said the bearings are not a snug fit so there is some slop there.
05-26-2008, 03:07 PM | #7 |
Hmm sounds like this is a common problem so maybe a vendor will come up with something to fix it? I was thinking of finding the right shims to take out the side to side play in it. On the other hand I don't see any reason why those parts can't be made to fit together tighter |
