07-09-2008, 06:31 AM | #21 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Looks very solid!
07-09-2008, 08:42 AM | #22 |
Rock Stacker Join Date: Dec 2006 Location: in the workshop
07-09-2008, 08:56 AM | #23 |
Pebble Pounder Join Date: May 2008 Location: El Paso
how can you go crawling with out any rocks?
07-09-2008, 06:37 PM | #24 |
Rock Stacker Join Date: Nov 2007 Location: CenFla
07-09-2008, 08:44 PM | #25 |
is your chassis the 'standard' AX-10 width, or is it a narrowed chassis? Very nice work on your truck! P.S.- can you send me some of those rocks? I need a small pile in my backyard. |
07-09-2008, 08:50 PM | #26 |
| Chassis is 70mm wide, debated on 55mm but I personally don't see the point of narrowing a chassis so it doesn't get hung up on rocks as much only to stick half the motor out one side, unbalancing the chassis, risking damage to the motor, and giving something even bigger for the rocks to catch - mabey theres some benefit that negates all of this but i havent found it yet so i'll stick to 70mm cause from the widest part of the trans to end of motor plate its barely under 70mm. As for the rocks once I get done "borrowing" enough for myself i'll think about it |
