06-09-2008, 10:40 PM | #1 |
Rock Stacker Join Date: Dec 2007 Location: 45th Parallel
| Hand Made Chassis with VF Dig-Servo Mod
It started so innocently with a Stock AX-10 kit in January. I made just a few changes and am please with the outcome. Chassis: 1/8" aluminum cut on the band & scroll saws & hand filed. Servo & Battery Trays: 1/8" Aluminum Front Steering Arms: GH Racing Aluminum Skidplate: Delrin / Nylon Cutting Board Motor: Novak Goat 21.5T with Novak ESC (Location: Rear) Gearing: 12T pinion - stock 87t Spur Shocks: Hot Bodies 4" - Semi Droop Config Links: Modified Stock Radio: TX-DX6 , RX AR6000 (Location: Front) Servo: Steering: JR DS8711, VF DIG: HS 225 MG DIG: VF Dig --Servo Relocated to be in parallel with the output shaft - off of the Dig unit Battery: Cheap Battery Packs 2/3 1500 ma NimH Tires & Wheels: Stock Rock Lizards (soon to change) Drive lines: Traxx Roll Over Hoops: Hot formed plastic -to protect ESC, RX & Spur Gear Clearance: 2.75"-3" Thanks to all for you assistance over the past few months. I hope to further contribute to the forums. Flynfrog / Ron Last edited by Flynfrog; 06-10-2008 at 12:53 PM. Reason: add'l title info-servo mod |
06-10-2008, 09:40 AM | #2 |
| VF Dig Servo mods
Due to a slip of the DIG servo linkage- I burned out one HS 225MG servo. After looking carefully at the Dig linkage as the servo was mounted on the Dig unit, I decided to dismount the servo. I placed the servo Behind (in front of the Rear output shaft) and in-line with the output shaft. The linkage (coming from a R/C Plane & Heli background) was causing some binding due to the long set screw & being offset from the center of the shaft. This causes a binding / moment arm torque on the output shaft nylon bearing. I have not had any binding issues since moving the servo. Flynfrog Last edited by Flynfrog; 06-10-2008 at 09:55 AM. |
12-20-2010, 09:59 PM | #3 |
Newbie Join Date: Dec 2010 Location: Chatsworth, GA
nice job
12-21-2010, 10:00 AM | #4 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Yea nice job. Them VF digs can be a little tricky on the linkage part but it looks like ya figured it out by trying to get it as straight of a pull as possible. One thing you might wanna try is making another skid little narrower than what ya have and try and narrow up your whole settup some. The narrower your setup the less likely to snag when in the tighter areas. Just something to think about, but I like what ya done so far. |
12-22-2010, 05:29 PM | #5 |
Newbie Join Date: Dec 2010 Location: ellijay
Looks good
