Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: reverse switch on RTR?
Old 06-11-2008, 09:42 PM   #1
Default reverse switch on RTR?
So my Axial RTR on the radio I "think" the throtlle switch was in the reverse position. Can anyone confirm? If I put it the other way reverse is forward and forward is reverse. Also the servo steer switch is reverse. Anyone know the original settings?
Deezul is offline   Reply With Quote
Old 06-12-2008, 08:31 AM   #2
Could it be something as simple as flipping the channel switches - I am assuming that the TX has such switches for each channel!! Normally there is a switch for each channel that allows you to reverse/change the function of the channel. Right becomes left, left becomes right. Forward becomes reverse - yadda yadda yadda
Of course, I could be missing the point of your question altogether!
SeanD is offline   Reply With Quote
Old 06-12-2008, 04:28 PM   #3
thats the thing both are reversed on the transmitter. is that normal on the rtr?
Old 06-12-2008, 04:31 PM   #4
look for a switch on the remote for reversing the throttle and steering there should be one but im not to familiar with the remote
pencrazy is offline   Reply With Quote
Old 06-12-2008, 04:32 PM   #5
there are and both are set to reverse. Is that how the RTR comes shipped?
Old 06-12-2008, 04:53 PM   #6
does it matter? just flip the switches
bulzeye is offline   Reply With Quote
Old 06-12-2008, 05:03 PM   #7
If remeber correctly my RTR came that way and all I did was flip the switches - but its no big deal flip the switches and get crawling.................
Eticket is offline   Reply With Quote
Old 06-12-2008, 05:41 PM   #8
thats what I wanted to know if I can just leave them in reverse because it seems to work that way
Old 06-13-2008, 09:07 AM   #9
Yes, there really is no "reverse". You just out them in the position that works properly and leave them there.
